Question about Nikon Cameras
NIKON COOLPIX L1,6.2 MG PIXEL,HAS A BLINKING RED HAND ,AFTER INSERTING A 4GB SDHC CARD,NEVER GOES AWAY,AND WORKS W/OUT MEMORY CARD.WHAT IS GOING ON,BAD CAMERA?...AND CANNOT OPEN MENU DURING RED HAND
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
    Scholar:
  • Nikon Expert
  • 163 Answers
I cannot find a Coolpix L1 it may be real old
If the camera is OLD 4GB will not work in it. many small cameras do have some memory inside.
You have to get an older SD that is much less memory.
Posted on Oct 25, 2018
6ya staff
SOURCE:
patmartini
  • 6 Answers
SOURCE: Nikon D40 Memory Card Error
Hello. Make sure the write-protect switch on the SD card is in the UP (nearer to the contacts) position. Try the card in an SDHC capable reader on your computer first. Note that the SD card can only be inserted one way - make sure you're not putting it in upside-down! If the computer recognizes the presence of inserted card (whether it can read it or not), format it at FAT32. When finished, remove properly (icon in system tray) and insert into your D40 slot, WITH THE CAMERA OFF!! Turn on the D40, and if it now recognizes the SD card, FORMAT it again, in the camera. Good luck.
Posted on Jun 06, 2008
robmcd27
Rob
  • 423 Answers
SOURCE: nikon coolpix L11
I'm sorry but you can't use the camera as a webcam. Here is why. There is no function on the camera to stream video.
Also, the camera goes into standby mode after 30 seconds (by default). And 3 minutes after that, it shuts off completely. It does that to save batteries. Again. I'm sorry. Good webcams average between $20. to $50. usd and they are made to work 24 hours a day 7 days a week.
You can use a 4GB memory card in your camera, as long as it's an SD card.
If you get that message, it means you haven't formatted the card for use in that camera. You have to format the card in the camera before you use it.
Even though the solution was not what you prpbably wanted, don't let it stop you from rating it a fixya. I would appreciate it. Let me know if I can help you with anything else, and thanks for coming to FixYa.
Rob
Posted on Feb 23, 2009
Anonymous
SOURCE: problem with Nikon d90
unlock your card. you'll get that message when the SD card is locked.  Lock the card only to prevent deleting photos from it. good luck!
Alberto
Posted on Mar 07, 2009
Lardzor
Lardzor
SOURCE: How to transfer Nikon Coolpix camera pictures to memory card?
Make sure you have an SD memory card inserted and your camera is on. Press the Play button to view your images. Now press menu and scroll down to the copy feature. You have two options, copy from camera to memory card is on top, and from memory card to camera is on the bottom.  Once you select your option, choose your pictures and copy.
Regards,
Lardzor.
Posted on Sep 13, 2009
Anonymous
SOURCE: Bought a new memory card for my nikon coolpix 3100 card wont work
It is too big. 1G is max for the 3100.
Posted on Oct 16, 2009
After inserting memory card in Nikon coolpix L105 the error 'this card cannot be used' has occured. what is the solution?
The L105 works with SD cards. Make sure you're not using an SDHC card. You need to use SD cards, 2GB and smaller.
Oct 29, 2012 | Nikon Coolpix L105 12.1 Mp 720hd Video 15x...
Have a nikon coolpix S8100 with a 4gb card. My hp photosmart 7960 reads "error reading card" when trying to upload pictures. I have no problems uploading my old memory card from my cannon A95.
The 7960 works with SD cards. It does not work with SDHC cards such as your 4GB card.
SD cards max out at 2GB. While SDHC cards are physically identical, they are electronically incompatible and will not work in devices not designed for them.
Sep 11, 2011 | Nikon S8100 Digital Camera
I have a problem with my memory card which supplied with nikon coolpix l4 and its is 512MB.now 512mb is not available so could i replace it with 2GB memory card.also let me know that 2GB card will support...
The L4 and its software will work with any size SD cards. Make sure you get SD cards, not SDHC cards. SD cards go up to 2GB, while SDHC cards start at 4GB and go up.
Jan 28, 2011 | Nikon COOLPIX L4 Digital Camera
Why my 4GB SDcard can not work at my NIKON coolpix 5900
There are no 4GB SD cards. "SD" cards larger than about 1GB are actually SDHC cards. SD and SDHC cards fit the same slots, but they are slightly different electrically. Many cameras won't work with SDHC (high capacity) cards. SDHC is not backwards compatible.
Jan 16, 2011 | Nikon Coolpix 5900 Digital Camera
My Nikon Coolpix P3 camera is not accepting my 4GB, SDHC San disk card?
The P3 works with SD cards, not SDHC cards. While SDHC cards will fit into the slot, they are electronically incompatible and won't work. You need to go with SD cards, 2GB and smaller.
Dec 05, 2010 | Nikon COOLPIX P3 Digital Camera
What kind of memory card will i use in this camera. Are all memory cards have a standard size.
You may use any SD or SDHC card. All SD and SDHC cards are the same size physically. Electronically, SD cards range up to 2GB while SDHC cards range from 4GB to 32GB. Any of them will work in the L110.
Dec 01, 2010 | Nikon Coolpix L110 Digital Camera
Nikon Coolpix 5900/4 GB Kingston SD Card
The 5900 uses SD cards. The 4GB card you have is actually an SDHC card and will not work in the 5900. You'll have to stay with cards 2GB and smaller.
May 19, 2010 | Nikon Coolpix S210 Digital Camera
Will my Coolpix 5600 use SDHC SanDisk cards?
Sorry to say, but . . . No!
Cnet Reviews shows the specifications on your camera.
2167fde.jpg It only goes so far as SD memory, which is limited to 2GB.
It's a hurdle technology manufacturers had to jump, and now consumers must jump also.
Jan 19, 2010 | Nikon Coolpix 5600 Digital Camera
PURCHASE THE PNY 4GB MEMORY CARD
I have the same problem with the card, my cannon camera, and my gateway laptop. From what I've learned in the past ten minutes, the card is SDHC and my devices are not. The card is not able to dumb down and I am returning it to Best Buy. The HC in SDHC is the issue from my best guess. Similar to you cannot play PS3 games on PS2. I hope this helps anyone else.
Dec 07, 2008 | PNY 4GB Secure Digital High Capacity...
Cameras Logo
144 people viewed this question
Top Nikon Cameras Experts
Ric Donato
Ekse
FIKRET UNALIR
FIKRET UNALIR
Level 1 Expert
Are you a Nikon Camera Expert? Answer questions, earn points and help others
