SOURCE: Telex DVD 7 tower Duplicator
it's not the heads that actually have the problem, it's the head guide that's sticking whenever it reaches those tracks mentioned. you need to open the drive initially to be able to repair or clean the malfunctioning parts. the read-write lenses be cleaned with cotton buds, and the stainless steil head guides be wiped clean and oiled.
SOURCE: CD-R problem
talkin about using windows built in burnin - unistallin nero started this problem
SOURCE: Error message: Can not scan. Not enough space on target disk
I have just cured this"not enough space on the target disc" on my set up.I had the problem from day one after buying scanner but learned to get around it.Today I went into Toolbox and opened settings and made a note of the target address. Then checked properties of the target folder and found there was 86mb in a space for 80mb.This was the default setting chosen by the installation programme. I went to my documents and made a new folder and called it Canoscan, clicked ok and it became the new target and the fault is gone. Hope it works for others.
SOURCE: My Teac 1x1 dvd/d11A/kit burner/Dvw/D11A: will
whatever software you are using to burn dvd;s, make sure the right burner drive is selected. if it is selected properly and still having an issue. that means the dvd writer is busted and can't detect a blank disc place into it. in that case, have it replaced.
