Question about Sharp Microwave Ovens
Sharp model R-409Y . Unable to keypad does not work after being out of use for 2 weeks for kitchen redo. Only shows _- _:_0 on display. Cannot set anything, no time, clock power, etc. How to fix?
Anonymous
SOURCE:
Anonymous
  • 213 Answers
SOURCE: thermador model sc272t oven 2 doors have dim display
there is a dispay kit you can order from bosch to fix this problem. it will come with a new display board and power control which is located behind control panel as well
Posted on Nov 19, 2007
BADBOYJAY
Jason Harris
  • 274 Answers
SOURCE: function button keeps failing
only do this if you relay know what you are doing. try asking your local appliance second hand shop it will save you time and money
Posted on Jan 05, 2008
Anonymous
SOURCE: Panasonic NN-C994S stop 2 sec. after I press Start.
Sounds like the power inverter
Posted on Apr 18, 2008
Anonymous
SOURCE: Amana ARGS7650 Keypad has no power
I had the same problem, same model. The electronic panel has to be replaced. This part is ~$215 before tax and shipping. With labor, I was looking at over $400. I bought a 4 yr old used GE gas oven for $75. That was my solution.
I believe the part to replace is labeled Erciii, gas
Part Number: AP4041311 made by WHIRLPOOL
This would have taken at least a week to ship (no one seems to have them in stock).
From now on, I will never own a range in which the oven or stovetop controls are electronic. Knobs and associated mechanics can be replaced MUCH more easily and cheaply!
Posted on Apr 06, 2009
Anonymous
  • 30 Answers
SOURCE: Negative weight on Salter Stainless Steel Kitchen Scale
make sure the battery your getting is a good one longlastig and if that doesnt work then how nout the motor
Posted on Aug 21, 2009
User manual for 1200 w carousel ser# 57088
Free Sharp Microwave Oven User Manuals ' ManualsOnline ...
kitchen.manualsonline.com > ... > Sharp > Kitchen Appliance Sharp
Products 1 - 50 of 359 - Sharp Microwave Oven 11452 User Guide. Pages: 0 Saves: 0 ... Sharp Operation Manual Microwave Oven R-308H, R-305H. Pages: 0 ...
Free Sharp Convection Oven User Manuals - Kitchen .
Nov 15, 2015 | Sharp Microwave Ovens
How can I to set clock on Sanyo Microwave EM-C678
1. Open door
2. Press clock/Kitchen Timer button the display will show "0:00" with the hour"0" flashing.
3. Enter the correct hour by turning the potary dial. Enter 1-12
4. Press clock/Kitchen Timer button the display will show "0:00" with the minutes "00" flashing.
5. Enter the correct minutes by turning the potary dial. Enter 00-59
6. Press clock/Kitchen Timer. The colon will remain flashing.
7. Close the door.
Sep 03, 2014 | Microwave Ovens
My Frigidaire ffmv162lw Microwave just shows "0:05" on the display and no buttons work.
You have a shorting membrane keypad. And you are correct - if and when an oven is coming on or doing anything by itself, this is very dangerous and can result in a fire.
So until it is repaired, please leave it unplugged or leave the door open when it's not in use, and of course one should never leave a microwave unattended while cooking, especially if it's doing this!
The details of my answer assume that your model number (from the tag on the microwave, not the manual) is FFMV162LWA (white). If not, please let me know.
On these models, the membrane keypad is not available as a separate part, so you would have to order the control panel frame assembly which comes with a new keypad.
In this case, you simply move your circuit board into the new frame. That is a simple do-it-yourself job.
You can order part number 5304477374 from the Sears Parts Direct Web site for $98.65 (prices subject to change).
There is a video here showing how to remove a typical over the range control panel assembly in under 5 minutes.
Then detach the keypad connector as shown in the photo below, and then remove the control panel screws.
Be careful not to crack the glass display when handling it, or it's a goner.
Reassembly is the reverse of disassembly.
Feb 16, 2014 | Frigidaire FFMV162LW Microwave Oven
I have sharp microwave oven model R-231F. On digital display (which is suppose to show time) only 88888 is displayed. suspect fault with the PCB behind display or keypad. Please advise how I can obtain...
First I would suggest a "hard reset". Simply unplug the oven for a minute or two, then try again.
If it still fails, it may be that the keypad has failed, or there is a bad connection due to moisture, grease, etc.
This is an Australian model, so it's hard for me to give more specific information.
But one some US models the LCD and keypad connect to the circuit board via a rubber "zebra strip" and losing that connection can result in a loss of display segments and / or key response.
I've attached a diagram showing where one can clean to restore operation in this case.
Oct 01, 2010 | Sharp R-1480 Microwave Oven
How do you replace the touchpad on a sharp
If one or more of the keys are not responding when you press them, it may need a new keypad, or it may just be that the connections need cleaning.
On some of these models, the display and keypad are connected to the circuit board via a conductive rubber zebra strip.
Sometimes steam (or spray cleaners!) can get in there and interfere with conductivity for the keys and/or display.
One would have to take it apart and clean the connections with high-grade alcohol, like 70% or better isopropyl from the drug store.
The attached photo is similar but not the same model.
If the keypad has been damaged or a cleaning does not do it, you will need a new keypad, and disassembly can be a bit tricky.
You can find links to helpful exploded view diagrams and part ordering help here.
I'd recommend that your bookmark this link to your favorites.
We regularly repair these control units for customers nationwide by mail for $39.95 postpaid in about a week or so with a one-year guarantee.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Jan 16, 2010 | Sharp R-216FS Microwave Oven
Sharp microwave 1200 watts keypad showing
Not a complete answer, but may help describe problem: Our R-510B should be the same except for color, and for several years it has intermittently messed up its display. The left side two segments on the units digit won't light up. So a digit 8, without the two vertical bars on the left, comes out as a letter E reversed left to right. Any digit that uses the two left segments (traditionally labelled segments E and F when talking about 7-segment displays) comes out wrong. Every thing else works fine. I can't tell if this is your problem.
This is almost surely a bad contact at the interface between the LCD display panel and the PC board: Typically there is a "squishy" conductive strip that connects them, and I expect grease has gotten in there. If so careful disassembly and cleaning with a mild solvent should fix it. Since we can live with it, and it usually fixes itself in a few weeks, I have not got around to taking it apart.
Bob Wilson
Oct 24, 2009 | Sharp R-510HW Microwave Oven
My Sharp Carousel Model R-370E No time display
We regularly repair such control units for customers nationwide by mail for $39.95 postpaid in about a week or so with a one-year guarantee.
If you decide to send yours in for repair, here is the info you need:
We have a service / repair manual for a similar model and have uploaded it to our site here to help you.
It should be similar enough to give you safety info and similar step by step help in disassembly info.
Most computers will open this document automatically, but you may need the free Adobe Reader.
We would really need the front door panel assembly (which contains the keypad, display board and connecting cable) as well as the power board to which the cable connects, as shown in the attached sample photos.
Feel free to contact me directly (and please remind me of your full model number from the tag on the unit) for more information & help.
William E. Miller, AS-EET
prototech@usa.net
Jun 14, 2009 | Sharp Microwave Ovens
Operating Instructions Mistral MMW17SS
Hi Bryan... I had the same problem as you in trying to work out this blasted clock!!! - by fluke I worked it out!!
Here are the steps:
1 - press the 'clock' button (to ensure the clock is displayed) 2 - press the 'cancel' button (the display will go to zero '0' 3 - use the keypad to enter the time (at this stage the colen between the hour and minute numbers will not be flashing. 4 - press the 'clock' button again (the colon will start flashing and the time will be set.
your frustrations are over my friend!
May 07, 2009 | Microwave Ovens
Sharp Carousel Model R9H84B
I've attached the portion of the manual which shows how to lock & unlock this model.
If that doesn't work, unplug the oven for one minute, plug it back in aga9in, then try again.
If it still doesn;t work, then your keypad has failed, and they are no longer available for these model, so the oven would have to be retired.
Good luck.
We're happy to help and we appreciate your thoughtful rating of our answer.
Jul 03, 2008 | Sharp R-230 Microwave Oven
Microwave Keypad not working
This model does have a child lock. If it's on, the display will say "LOCKED". It is turned on and off by holding dfown the "0" key for 4-5 seconds. You may also have a bad keypad, which in many cases can be replaced. A bad keypad may be worn out due to age, damaged, or it may have gotten wet or otherwise contaminated. Moisture and contamination can be caused by spraying of cleaners, by storing the microwave in an unheated garage or shed, or infestation. I warn my customers to never spray cleaner directly onto the microwave keypad, since the liquid can get inside and "lock up" or even ruin the keypad or controller. Apply an alcohol-based cleaner (such as the purple kind) to a cloth (paper towels can scratch) and gently wipe it off. I suggest to my customers that they NEVER use any ammonia-based cleaner (like the blue stuff) on a microwave, since the ammonia will crack and distort polycarbonate plastics. Repost if you need more help.
Nov 04, 2006 | LG LMVM1935 Convection/Microwave Oven
Microwave Ovens Logo
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Ekse
Gerry Harvey
Gerry Harvey
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
