Question about Electrical Supplies
The rubber where the gas tank shutoff fits on is broken, where to find one?
Homelite generator, ut03781-b, model # lr 4400
    Top Expert:
  • Electrical S... Master
  • 54,386 Answers
Homelite would be a possible source.
Posted on Sep 06, 2018
4 Suggested Answers
6ya staff
SOURCE:
freetek
Steve Allison
  • 5569 Answers
SOURCE: just up graded from a homelite 4400 to a craftsman
Some manufacturers tend to fudge the numbers and throw around the 'peak' output power as continuous and it isn't. Peak (or surge) is the power a generator will handle as starting current (for example) for a motor and can be 120-140% of the actual continuous power.
Check you owner's manual, find the detailed specs which will normally contain the maximum continuous current rating. If it is listed separately for 120 and 220 (240) volts look for separate current ratings for each output.
By multiplying the current(s) times the output voltages you can find the total resistive output into a purely resistive load such as an electric heater.
For example: 120VAC X 20 A=2400 watts. If other outputs are available such as 220VAC, multiply its current rating: 10A. or 2200 watts Adding those two results 2400 2200=4600 watts will give you the rated power of a unit.
You can also recognize stupid power claims if the engine's horsepower is given. One (US) HP = ~746 watts. Since no generator is 100% efficient, its a fair rule of thumb to guesstimate the available electrical power at ~70% of the engine's rating (although, this is often also wildly optimistic). 10 HP X .7= ~746 X 7 or a bit over 5,000 watts.
Posted on Oct 03, 2010
joe leier
  • 185 Answers
SOURCE: How do I remove the
Here is a copy of the owners manual and it has an exploded diagram that you can follow to remove the generator part. When you take off the back mount and then you will see inside a coil that rotates, this is the rotor, and a coil that is stationary around the rotor, this is the stator. Make sure that you take good photos and mark all wires that you disconnect, this helps in re-assembly later. To remove the back support called the brush head, you need to remove 4 long bolts and one in the center that holds the rotor to the engine. Gently tap the brush head away from the stator with a small hammer. You might need a small blade screwdriver to pry, remember GENTLE is the word here. Now, you might have to block up the stator so that it is supported since the brush head is removed. The stator might need some gentle prying to remove it from the engine. When pulling the stator off, be careful that you do not drag it on the rotor, this might damage the rotor. With the long bolt that held the rotor to the engine, screw it in and leave about 1/8" of it out so that the head does not make contact with the rotor shaft. Now with a small hammer, strike the head of the bolt while at the same time pulling on the rotor towards the head of the bolt. The rotor should come loose and you remove the bolt and pull the rotor off gently. To install, you never need to use the hammer to mount the parts.
http://www.manualsonline.com/mdownloads/c1983037-0926-41f5-b48e-951b3980f90f.pdf
Posted on Dec 26, 2010
Jeff Chapman
SOURCE: Homelite generator model # LR 5500 not producing electricity
I have the same unit and same problem.
I have lost my owners manual. Did you figure out what needs to be done to correct the no output issue.
Posted on Jul 13, 2011
Fuel mixing with oil and filling oil tank and cylinder.
the ethanol gas has a way of ruining the rubber tip on the needle valve (in carburetor). When the rubber tip on that valve or the rubber on the Seat go bad, gas can constantly want to fill the carburetor bowl. so much so that it runs into the engine cylinder and past the Rings to the crankcase.
You can replace the needle valve and seat in the carb which is best OR you can put an in-line shutoff on the fuel line and turn it off when you are not using the generator.
Ethanol gas.. very very bad for carburetors.
Sep 05, 2015 | Garden
On a homelite model 26 bv blower Does the gas tank filter connect to anything
The filter fits on the end of the fuel pickup line inside the gas tank. If you see the filter just rolling around in the tank it probably has hardened or damaged fuel lines. Size them up and get replacement lines online or at your local outdoor equipment retailer.
Oct 06, 2014 | Homelite Garden
Gasoline generator homelite 4400 watt will not run getting gas spark plug is fireing but will not start..
If it has sat for a while, empty the carb. float chamber, flush out with clean fresh petrol. Make sure fresh petrol is in the tank and try again.
May 13, 2014 | Briggs & Stratton Briggs and Stratton...
Homelite 26gc
That's your fuel filter.
It needs to be/has to be connected to the fuel line going from the carb into the gas tank to get gas to the carb.
Make sure your fuel line is not broken/split.
Feb 05, 2018 | Garden
I have a Homelite 4400 generator and it will not generate power
Why My Generator Won't Produce Electricity
Generator is a device that converts mechanical energy into electrical energy for use in an external circuit. At present, generators are widely used in industry and agriculture, national defense, science and technology as well as our daily life.
Oct 31, 2011 | Electrical Supplies
My Homelite XH2XS-0254RA Trimmer gas lines have broken off inside the gas tank, can replacement parts be obtained
Hi carlfreeland...
Yes, your fuel lines can be replaced, be sure to get the right size to fit your machine.
Go to your parts supplier with the model/serial number and manufacturer of your weedeater.
Most of the time there will be two size fuel lines, the bigger one is the one the fuel filter inside your tank is connected to.
Please take time to rate me
Jul 03, 2011 | Homelite Expand - It Brushcutter...
Mar 07, 2010 | Electrical Supplies
Homelite 6000 Generator running rough, now won't start
Sounds like the engine is not getting enough fuel. Two possible problems:
1) I know this is a dumb question, but did you turn the fuel back on?
2) If the answer to question 1 is yes, then the small fuel filter inbetween the gas tank and carburetor probably has hardened. The inside of the fuel filter is a piece of foam and it is really common for the in line fuel filters to harden when no fuel is present and cause a clog in the fuel line. Try replacing the inline fuel filter and life should be good!
Jan 27, 2010 | Homelite Consumer Products 9.0 Amp, 14 In....
Just bought a used leaf blower, homelite, gas leaks out of the gas tank, where the gas tube fits into it.
"top of the gas tank where the gas tube fits into the tank"
I assume you're describing the gas tank cap. if so, the o-ring is missing from the gas tank cap. You can find those at hardware stores.
May 29, 2009 | Homelite 'Yard Broom' Leaf Blower
Electrical Supplies Logo
73 people viewed this question
Top Electrical Supplies Experts
Gene Haynes
john h
Are you an Electrical Supply Expert? Answer questions, earn points and help others
