When plugged in, There is no evidence that TV is getting power. Power button does nothing. How many conditions can cause this?
SOURCE: no power when power button is pressed
I would have to say you have a dead power supply. You will want to make sure first that the "MAIN" power switch located on the lower left on the rear of the unit is turned on as well. Without that on there will be NO standby light.
SOURCE: blinking power light
This set has a power supply and signal PCB. Since the indicator light is blinking, I would consider the problem to be a missing voltage from the power supply. Unplugging the set for a couple minutes may solve the problem. If not the set may still be under warranty. Contact LG (800) 243-0000 for a servicer in your area. Hope this helps.
SOURCE: Unit will not power on, has the standby light on
I took your advice I unpluged the unit then held the power button in then pluged it back into power outlet the unit came on. There is one thing I might add I had to do it twice before the unit came on. Now how long will it work? Who knows
SOURCE: MY Sylvania LC321ss9 TV just shut off today!
It means your power supply went out. I had a sony with the same symptons and it cost 140 to fix it.
