SOURCE: Reset Timer Lamp Sony VPL-HS60 projector
To reset the lamp timer:
1) With the projector plugged in and turned off, press the 'ON/STANDBY' button to put the projector in 'STANDBY' mode. NOTE: You have to press the button on the projector itself, you cannot use the remote for this step (this is not clear in manual).
2) Now, using the remote, press the following keys in order: RESET, <--, -->, ENTER.
3) Timer should now read '0'.
SOURCE: Lamp time resetting
HI
Not sure if its in the handbook but you can download a copy from here
http://safemanuals.com/user-guide-instructions-owner-manual/SONY/VPL-CS5-_E
SOURCE: how to reset lamp on sony lcd projector xga vpl-px20
After replacing lamp, connect projector AC power cord and turn the projector in standby mode.
Press following keys on control panel for less then 5 seconds each..
RESET, <==, ==>, ENTER.
That will reset lamp timer in projector.
Thanks.
SOURCE: sony vpl-hs20 cineza projector- reset lamp counter
These instructions are for a Sony Cineza VPL HS3, but may be the same for the HS3.
1st thing to check - is the cover properly/completely closed - this can stop the projector from working.
Connect the power and set the projector to standby mode.
Press these buttons on the remote control in this order, for less than 5 seconds each.
Reset - Left Arrow - Right Arrow - Enter
This is required, to reset the lamp timer.
Also, something I found interesting from the internet - lamp life isn't
when the bulb dies, but when a bulb has lost 10% of its brightness - so
you might well be able to reset the timer and get much more use from
the bulb - the image just wont be as bright.
