This is because I need more storage space. If I just delete it, would that cause problems? There is no Navigon app, just the folder, so I do not know what its function is.
SOURCE: folder unreadable and corrupted. files lost.
hey down load PCI recovery for recovery of files
SOURCE: cannot delete ESET folder from Program files. the
Apparently MS in their infinite wisdom decided that in vista they would take the power away from the user and remove the administrator from the equation.
So no matter how many thing your try in the user accounts you will not get full admin rights.
but here is a reg hack that worked for me real well. I am running windows vista home basic
Click Start and Run type in regedit and enter
your now at the registry editor.
click and expand HKEYLOCALMACHINE
go down and click SOFTWARE
click MICROSOFT
click WINDOWS
click CURRENTVERSION
click POLICIES
click SYSTEM
you will see the registry entries to the right
right click in the white area and select new DWORD
Name it "EnableLinkedConnections" and enter
Right Click on EnableLinkedConnections and choose MODIFY change the Data Value to "1"
Save and exit Registry Editor
Reboot your computer and try deleting the folder you wanted to again.
WARNING:
Using this reg edit you are changing your registry and could develop problems if you don't do it correctly. Be Warned and do some research prior if you need to understand registry editor.
SOURCE: what is pc health
Pc health is a new virus. I am trying to disable it. try renaming the files in the folder with a right click or some other way if the other tries do not work. Also change the folder options by first making the PCHEALTH folder read only and then making it all not read only.
you will have to delete the User and Software registry keys after reinstalling windows.
SOURCE: My HTC P4350 is running low on free storage space
The system have used nearly the maximum internal memory available: Storage: Total 33.45 MB; In Use: 32.80 MB; Free: 0.66 MB Program.
If you already deleted or moved to memory card your files, that means that the space is taken by installed application/games, or by files left over by previously installed applications.
Save all your files on computer and do a complete reset of the HTC, restoring system to factory settings.
SOURCE: Weird folder/filenames that will not delete
Problem: Folders / files in USB flash drive got named with weird strange characters & those folder / files cannot be copied or deleted.
Reason: Virus infected
Solution:
1. Click on "Computer"
2. Right click on the drive that contains USB flash drive
3. Select "properties"
4. Click on "Tools"
5. Click on "Check Now"
6. Check disc options will appear on screen, put a tick mark in the box in front of Automatically fix file system errors
7. Tick mark in the box in front of Scan for & attempt recovery of bad sectors is not necessary.
8. Click on "Start"
9. Upon finishing of this task, screen will show message "Your device disc was successfully scanned" and bla bla. Close it.
10. After this process the undeletable folder in USB flash drive can be deleted by selecting it & deleting it. The contents of affected folders files cannot be recovered.
After lot of struggle I got this solution on my own by the grace of God.
Sure it will work for others too.
Thanks and regards Raju
I don’t know if this is relevant but I have an app called Navigation, but this is not listed under Application Manager, which seems strange. I wonder if they are connected.
Thank you,Minister Ruland. As I have no Navigon app I have now deleted the folder and all is well.
