Hello, Kelly -
If you wish to try to remove the video tape yourself:
1. Unplug the machine from the electrical outlet and unattach the wiring/cable from the TV and any other electrical units (like a cable or satellite dish receiver.)
2. Unscrew the screws attaching the unit top to the rest of the machine. Note: There will probably be printing on the tape player combo warning about opening the player.
3. Remove the top. You will probably see the stuck video tape in the machine and may be able to carefully pry the tape cartridge out. Note: The video tape may be mangled in the rollers through which the tape runs. You may up ending damaging the video tape and/or the tape cartridge.
If you choose not to try to get the tape cartridge out yourself, find a TV repair business near where you reside, take the player there an let an authorized repair person extract the stuck tape cartridge and pay the repair price.
Note: Years ago, when I made my home "toddler proof" for a visit from my niece and her toddler son, after they left, I found I could not insert a video tape into my player. After taking the player to a repair service and paying the fee, the person at the business handed me my player and a plastic electric outlet cover which my grand nephew must have pulled out of an electrical outlet and stuck into the opening for the tape cartridge. After that, whenever I encountered problems with the video player, I took it upon myself to open the unit up. :)
Best wishes.
SOURCE: Magnavox combo vcr dvd
What you're describing is common when the center LED has failed / gone out. If you're really good at taking a unit like this apart and putting it back together - and not too bad with a solder stick you could attempt this one yourself... It is a pretty intensive repair but not difficult for a good shop just time consuming. The part isn't too expensive either, just an infared LED... In fact, we've run a bit short on stock once in awhile and bought one of the off the shelf versions from Radio Shack which worked just fine. Good Luck Bill
SOURCE: TVSC1320 13 in. combo from January 2000 VCR Tape is...posted by jcs123 on Dec 23, 2007
This guide should help you.
SOURCE: stuck tape in vhs/tv combo
Unplug the TVCR, take the cover off, find the motor (probably on the
right side of the mechanism) and turn its shaft with your fingers until
you have run the tape back out. Now plug it back in and try it
again with a scarificial tape. If it continues to fail, replace
all the rubber belts in the mechanism.
Hope ya fix it!
SOURCE: Stuck VHS Tape in Samsung TV/VCR Combo
HI,
Please unplug all the cords of your TV for 4 hours and allow it to reset.After 4 hours plug the cords back in and now try removing the tape.
Let me know the result
SOURCE: Stuck VHS tape in Samsung TV/VCR Combo
I told you in premium post that Unplug your Combo for 5 - 10 minutes from AC outlet and replug it. Now push eject button and take out cassette.
