SOURCE: My machine (Hoover Wind Tunnel - bagless) is only
Sounds like you should do two things:
1- Remove and clean the beater brush of all debris as best you can. At the end of the brush you will see a hard rubber piece, at both ends, that holds it in place in the body of the vacuum.
Add some WD40 between the brush and these pieces and turn until they move freely.
2- When you reassemble, put a new belt on.
This should be all you need to do.
If you find this information to be of help, I would appreciate a Thumbs Up from you.
Be well,
Paul
SOURCE: I need a users manual
you can download the manual on the lick below.
http://www.sharkclean.com/manual/NV350W_26_IB_ENG_101201.pdf
Good luck & please rate if it helps.
SOURCE: instruction manual for shark model 3901k lift away steam pocket mop
click on the link below for the manual
http://www.sharkclean.com/manual/S3901K_N_11_IB_E_120410_3.pdf
