SOURCE: Switch settings on stanley garage door opener
check the pin configuration on the back of the Stanley 3200
SOURCE: i installed a model hd900d
My best advise to you is get the brand name remote for your opener. I know it sounds like a pain but click brands are not super great because there supposed to work for many different kinda. For the most part you can call your local garage door dealer and pick one up for your opener. They may sell you a lift master brand opener which is find sears/liftmaster/chamberlain are all the same. Should only be about 35 bucks if you pick it up
SOURCE: have chamberlain security plus 950cb lost instructions.
http://www.chamberlain-diy.com/doityourself/pdfdocs/114A2184.pdf
This web address came from the Chamberlain site. I also needed to relearn my remotes due to a newer car that has a built in garage door opener that needed to be set. I also needed to reset my keypad remote, those instructions I was able to get from the same site. Good Luck
SOURCE: Craftsman Model 139.53684 Security+ Keyless Entry
To answer your question the opener is in vacation mode. Press and hold for 3 seconds the button on your wall control with the lock icon. The green light will stop flashing and you will be back in business.
