SOURCE: problems with mitsubishi WD 65737
problem with mitsubishi wd65737. thought the bulb was bad, bought a new bulb replaced it and now the screen doesnt want to come on. light on the front of the tv turns green, you have sound but no picture then the tv turns off the light on the front is now steady red. resetting the sytem worked yesterday but not today.
SOURCE: Mitsubishi wd 65737, tv gets to the welcome screen
Try unplugging the power cord for 60 seconds and plugging it back in. We had the same problem and that worked the first time we tried it. The problem is back and, after some frustration, the manufacturer recommend updating the software. Contact your local Mitsubishi service rep. to obtain updated software and instructions. Good luck!
SOURCE: WD 65737 blinking two digit code of 3-6
your exhaust fan has failed you can get the replacement fan from www.tvrepairworld.com
SOURCE: wd-65737 screen comes on with mitsubishi logo then shuts off ,red light blinking
Here is a suggestion that has worked for several people:
http://www.fixya.com/support/t12296849-turns_off_shortly_after_turn?mt_f=viewFull162
SOURCE: Mitsubishi sent me upgrade pluged in in my 65inch
I worked for a repair shop that did authorized repairs--seen this before.
Some info for you, the set has two resets (other than the one on the front if there) One is the soft reset: set on: Menu, 1,2,3, enter.
The second I do not have but the set has it (my information for that does not cover this model) It is also done with the remote and a 4 number code that when done restores set to factory and it may or may not help if the software was altered.
Try the 1,2,3 method as it will not hurt and could help.
Any authorized Mitsubishi dealer will be able to call up the hard reset code and let you try it----YOU NEED TO DO EITHER WITH THE Mitsubishi remote.
SD TECH
