SOURCE: unable to connect to my device
I had this problem with my YP-U3JZB, and this worked:
Plug player into USB port. Then do: Control panel > System > Hardware tab > Device manager > Portable devices (expand and locate name of device, eg "Samsung YP-U3") – right-click and select “Update driver”, follow prompts.
This worked without installing the Samsung media player – Windows Media Player 10 or 11 will then recognise the device, for syncing, etc.
(found this solution in another forum, can’t now locate – anyway, props to them!)
SOURCE: IRIVER PLUS 3 MEDIA TRANSFER SCREEN
My understanding, as a new user, is that IRiver plus 3 only communicates with the player via UMS mode, which is not the default. Windows Explorer and Windows Media Player only communicate through MTP mode. If you change from MTP (the default) to UMS, it will reformat the player and delete all your files.
In other words, do not use iriver plus 3 unless that is the only software that you want to use. Boing back to MTP mode after a sync or download will then delete all THOSE files you just downloaded.
I just say NO to Plus 3.
Good luck.
SOURCE: RE: SAMSUNG MEDIA STUDIO 5
how can i solve a [problem with my mp3 playerit will not install or put music on 2 it
SOURCE: samsung yp s3 doesnt work on xp
I have Windows XP and Media Player 10.
I had same problem with Samsung media studio not recognizing MP3 player. Here is how I fixed it. With the MP3 plugged in, I had to go into System/ Hardware/Device Manager and find the S3 driver under "Windows portable Media" and uninstall it. Then unplug and replug the S3 into the usb so that driver gets reinstalled.
Then I decided windows media player and samsung media studio are unnecessary for transferring music files to MP3 player.
Instead I go into Portable Media Devices from the control panel and just treat the MP3 player like a usb device. I copy folders of music and songs into the Music folder on the MP3. For me this is way easier than the Samsung music studio or Windows Media player.
SOURCE: i am using samsung GT-S5230 mobile .
just do mass storage or media player and it will still find the device and recognise it as a removable drive
