We have bought the TV and now that we want to use the DSTV now app. it says it is not certified, how do you fix it?
SOURCE: my sansui smart 14 color tv. Now few days all colors dont matching.Plse help me.
hi there, maybe you have a magnet or speakers near your screen, check some parts maybe coldsolder problem and some cleaning needed. ty
SOURCE: 32 inch sylvania tv
This problem is caused by your TV's V-chip setting.
To fix the problem:
Push the "Menu" button (on either the remote or the TV's fromt panel).
Use the "Channel Down" button to go to "V-CHIP SETUP"
Use the "Volume Up" button to select it.
In the V-chip setup screen, the rating that is selected by the user as viewable will allow that rating and only lower ratings to be viewed on that TV. (If TV-G) is selected, then any programs rated higher than TV-G will be blocked.
So, the easistway to get rid of any blocking is to set the rating to TV-MA (mature), and then any and all programs will be viewable on that set. Select "TV-MA" by hitting the "Volume Up" button after you have scrolled down to that rating with the "Channel Down" button.
Then hit "Menu" to exit out of the settings and saave your changes.
SOURCE: setup 32 inch sansui for digital reception
1) Connect your signal source - either CABLE or ANTENNA.
2) Go into your menu and select your signal source to match.
3) SCAN in the channels. This will give you all channels available.
Your User Manual will give you all information.
If you are on cable, you may have to check with your supplier to see if they carry local stations.
SOURCE: black and white dstv
look on the TV menu for (system) in south africa we use PAL, if you cant change it on the TV, with the decoder remote press menu then 7 then 4, it will ask for a pin code press 9-9-4-9 it will read "RF modulator" press OK, it will then read 1 MODULATION press ok again and it will highlight PAL I now press the right key and press OK, if this persists then the decoder it probably faulty... good luck
SOURCE: Ihhave a 32 inch Luxor smart TV and I need to reset it back to factory settings can anyone help me?
There are two types of reset to TVs. The first is simple to do; a Hard Reset; and the other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight; will be better. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
I have the exact problem, how did you solve it?
