SOURCE: Refrigerator Compartment Fan
Sounds like they ran it in with your themostate and it is not working.. i would try replaceing themostate
SOURCE: FREEZER SOUNDS VERY NOISY
Fridge problem could be the fan is bad or that it is hitting ice. When the noise is kind of a buzzing like it is hitting ice...defrost your unit by unplugging and waiting a day or so for full melt out...then check your door gaskets for cleanliness and good seal.
Thanks.
Is there frost on the back panel in the freezer, If so change the defrost heater. If not is there anything running?
SOURCE: freezer door pops open when fridge door is closed.
well u need to check the rubber of ur freezer ;s door .some damaging in the rubber is causing the problem.
SOURCE: motor noisy, stops when open refrigerator door
i had this problem then turned off fridge freezer for 24hrs and it was gone it was more or less needing defrosted
