You can download the complete instruction manual in PDF format by clicking this link.
You'll require Adobe PDF Reader installed on your computer to view the manual. If it is not already installed on your computer, download it free from: http://get.adobe.com/reader/
0392. Check this code. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily. http://remotesearch.blogspot.com/ http://electronicshelponline.blogspot.com/ http://electrohelponline.blogspot.com/
Type in the brand name of your device, in the search box [at the top right] of the display window and the Search will start at once as you type in, and will show you all the related posts. It will make surf easy.
When you put the player into rewind, is it at the beginning of the tape that it ejects? If so, it may be because you have the machine in timer mode. If you have a pre-recorded tape in a VCR, it will automatically eject the tape because you`ve not to record on a pre-recorded tape. I hope this help, Ian
All new VCR's are auto tracking however, you should be able to manually track it using your remote, or there are a few reasons that the auto track can fail, the tape may have worn or ragged edges which means that the control head cannot get a clean reading, the control head may itself need cleaning or the tape path requires adjustments, adjusting the guides really needs to be done by a technician as a reference tape is used, or that the heads are low and a good video signal cannot be obtained to gain a reference point....Phil
Most VCR's do have a sensor system inside. It consists of what looks like a bar that is standing up right in the middle of the area the tape sits down into, and sensors on one or both sides of the tape bay that detect this source. The source is usually an infrared diode, and it is most likely this diode that has malfunctioned. I would checjk to see if anything has gotten inside that might be blocking this sensor, if not then the diode probably needs replaced.
Found no info in manual but cleaned tape heads and able to watch tapes. I don't know if this completely fixed problem because tape watched was not best quality.
here is a link to download the manual for your vcr - http://www.usersmanualguide.com/funai/video_cassette_recorder/6240ve - hope this solves your problem.
Press the Channel up & down buttons at the same time and on most VCRs this deactivates auto tracking option. then press the up or down channel button to adjust tracking.You might try this first. pressing them both at same time reactvates auto tracking. This might not solve the problem but at least you eliminated one possibility.
