I would like to order the #116 taper gear for a mastercraft table saw Model # 055-6747-8 if possible. I have tried the 1-800-689-9928 Canadian Tire customer service line and am still on hold after one hour and 15 mins
SOURCE: THE BELTS ON MY MASTERCRAFT OSEILLATING SANDER ARE WARN OUT
Maybe you can use a linked belt. Take a look at this link
(pun intended)
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread. If I've managed to answer your question or solve a problem, please take a moment to kindly rate this post....thanks!
SOURCE: I need a parts Diagram for a MasterCraft 8.25'' Compound Mitre Saw
I have the manual and prts list , you can phone this number for parts, the parts depot is in Ottawa 613-724-7724. if you the diagram send email to [email protected] and I will send it to you.
SOURCE: Will Delta Belt fit Mastercraft Band Saw
If you still have the old belt, take it to a well equipped hardware or auto parts store for a replacement. If the previous belt is missing, you will need to measure the pulley 'V' width at the top of the 'V', the center to center measurement of the two shafts, and the outer diameters of the two pulleys. Hope this helps!
SOURCE: Mastercraft Maximum Compound Mitre Saw
Mastercraft's help line is 1-800-689-9928. However this saw is no longer in production and parts are available only until stock is depleted. It was supplied by an european company called WMH Tool Group that apparently doesn't supply CTC any longer.
SOURCE: My husband lost the safety key for our Hitachi
I found Hitachi customer service to be quite helpful in replacing my safety switch for my C10RA2 table saw. My C10RA2 has a fixed metal stand, not the folding stand, and the part number for the red safety switch or key is 531-992R, while the switch itself is part number 314-459. If you have the folding stand the part number for the switch is 321-620 and the safety key is 321-621. Hitachi customer service in US: 1-800-706-7337. I am going to buy two or three! Almost lost a table saw over a cheap plastic part.
