SOURCE: Location of GE refrigerator circuit board
The main board is located behind the unit at the lower right hand corner behind a panel that's about 8" X 12".
SOURCE: Our water line on the refrigerator is leaking? Can't find the shut off valve?
most are located under the sink,so are located behind the frig.-mike
SOURCE: GE refrigerator won't keep cool
check the voltage going into you fan w/ the old main board and also w/ the new board. You might be getting a low voltage w/ your new board or the fan you replaced is for a diferent voltage. Have you tried to put the old fan back w/ the new board??
SOURCE: ge side by side refrigerator model GSH22JFTABB.
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
SOURCE: problem with GE G.e refigerator Wr55x10942 Motherboard main board
You will need to replace the board. Here is the board to order.
