Hooked with digital cable, was working before?
* Brand, model for specific information.
* Check your warranty call for support.
*** Following is for information only.***
* Many times when hooking up new equip one must read the instructions as to the new configuration may be different with the older set up.
* As of Jan 2018, cable boxes have switched to all digital output.
* Outputs can be separate video and audio or combined as with the HDMI cables.
* Check your TV input set up to select the right cable input; HDMI-1, HDMI-2, COMP. Note; RF input may not be available in certain areas.
* The COMP input also needs an audio (in stereo) input from the cable box. It's usually a RCA plug (White and Red) The video will be 3 separate "colors" RCA plugs that needs to be matched to the correct input.
* You will also need to check your TV menu for the audio settings if it is set up for your current speakers set.
* Check with your cable provider for additional support.
Aloha, ukeboy57
SOURCE: VCR DOES NOT WORK WITH NEW CABLE BOX
If you can get some of the stations without the box (often the case for those who subscribe to digital cable or movie channels), then one setup is to split the raw cable and feed the box and the TV, then have the box feed the VCR and hook up the VCR composite video and line level audio outputs to the TV. The VCR tuner would always be set to the VHF frequency your cable box RF output is on, usually ch. 2, 3 or 4. This setup allows PIP to work, with the TV tuner limited to unscrambled analog stations, and it also allows you to tape anything coming through the box, while watching unscrambled analog stations on the TV. However, it requires the VCR to be on and the TV set to the external video input to simply watch what is coming through the cable box. There are other ways to set this up with more flexibility using splitters and A/B switches, or you can look for a special switch box that handles the job. The above assumes your TV has composite video and line level audio inputs. The only way to have full flexibility to watch any scrambled or unscrambled station at the same time as taping a scrambled station is to have 2 cable boxes. The only way to have your VCR control the cable box and record different programs by switching the box by itself is to have a VCR with a cable box controller, also known as a cable "mouse". Hope this helps
SOURCE: hooking up to digital cable box
Darth,
There are 2 ways you can accomplish this.First is the least quality which is via coax.What you want to do is connect the cable service coming from the wall to the input on your cable box.Then the TV output on the cable box goes to the input on your surround sound then the coax goes from the surround sound to the coax input on the TV.The second is to Connect using the RCA AV1 input.what you want to do is look at the back of the digital cable box and locate the OUTPUTS for the RCA jacks(or AV output)connect RCA cables (yellow red white) to the 1st INPUT on your surround sound.depending on models you should have a couple of different INPUTS for a signal.Choose one and plug it in.After that take a second pair of RCA cables and connect them to video OUTPUT on the surround sound and connect them to your AV1 OUTPUT on your TV.With the original remote for your TV,NOT the cable universal one,Look for an INPUT button on the remote.Some are called input some are called SOURCE,TV/VIDEO basically it tells the TV what signal source to look at on the back of the TV.If you dont have the remote put the TV on channel 3 then press the channel down button and when the TV gets to channel 1 press it again and it should start cycling through the AV inputs,choose AV1.
Once you have done this you have correctly
hooked everything up,BUT Like I said depending on the model of surround sound you are going to have to CHOOSE or physically select or "tell" the surround sound receiver which input to RECEIVE the sound through.In general the INPUT on the back of the surround sound will be labeled with something like Video IN,VCR IN, DVD IN and so forth.Make sure the surround sound is selected to Receive the sound coming from the digital box.Sometimes there is a dial on the front of the surround sound that allows you to select which INPUT on on the back becomes active .make sure that what you have selected matches what you have your cable box is connected to.Hope this helps!
SOURCE: Sharp Aquos LC46D64U
No reason for the audio not to work on the RF cable. Check under menu and option and make sure audio is set to fixed and not variable.
SOURCE: no signal when hooked up with a digital cable box
I had the same problem and had the cable guy out and everything thinking it was my box. I figured it out by myself here is what i did to fix it. I have the vizio 32 inch hooked to an hdmi cable and through the cable box i had the aspect ratio on 1080i and i should have had it on 720p once I switched it I havent had the problem since.
SOURCE: Problem hooking up DVD player to TV thru my cable box
Chances are you've got your DVD player hooked to OUPUT jacks on the cable box, not inputs. I haven't yet seen a box that takes any kind of an input other than the cable line, but they will have RCA jacks for audio and video outputs on the back. So your cable channels are fine, but the DVD signal is hitting a dead end.
The only solution if your TV doesn't have RCA inputs for video and audio is to get an RF converter (around $10-$20). This takes the A/V signals from your DVD and turns them into a channel 3 or 4 signal that connects to your TV's antenna input.
The converter also has a connector on the back for the cable coming from the cable box, since you'll have to disconnect that from the TV. When the DVD player is off, the cable box signal gets passed to the TV as normal. Turn on the DVD player and the RF converter switches on; put your set on channel 3 or 4 and you'll see your video.
One final thing: The converter will need an AC outlet for its power adapter or power cord, so make sure you have a spare. If you don't already have your TV and DVD player connected to one, this would be a good time to pick up a surge-protector outlet strip. Then not only will you have enough outlets, you'll be protecting your equipment as well.
If this solution has given you what you need, please take a moment to rate it appropriately. And thanks for asking here!
Testimonial: "Thank you. I forgot to thank you when I first read this response. Works fine now though :)"
