Can we know what is, ? ahh a TV posted to computers, well im moving you.
what is wrong, ?
all you can do is find old parts on Ebay, or the large parts houses only (scalpers)
i looked in ebay and behold the main board in some kind of monitor.
google for it?
but that gets lots of scalpers.
SOURCE: Cross-referencing databases
This should be relatively easy, just create a query that has an equijoin on the name fields. If you're worried about misspellings, you could match on a soundex of the names.
SOURCE: part number for motherboard?
just look ur Processor and memory what kind of motherboard can support.
SOURCE: I live in Australia and am having trouble finding
You posted 2 different engines. The parts are different for each.
1986 V8-302ci 5.0L F/I Vin N --1986 L6-300ci 4.9L 1 BBL Vin Y
The F955 (Wells), is for the push on style. (triangle shaped)
Not showing a cross to Bosch or Champion, but it will cross to these brands.
Napa #FA144SB -- Borg Warner #D166 -- GP Sorenson #FR107 -- Federated Ignition #D166SB.
If you can get MSD ignition parts, the cap and rotor kit #8482, (JEGS PART #8450).
SOURCE: i have a transistor mx d362. need cross reference part number
If you know the input and output voltage, and the approximate current capacity just replace it with a commonly available regulator of a similar rating.
Go to website rockauto.com and put your vehicle info in there. They list pretty much every name brand plug that is easily available for vehicle. Only thing it may not show is old "obsolete" plugs that may work - but you probably want to avoid old plugs anyway. They changed plugs to newer materials that can handle the hotter spark and higher temps on cars running injection and CAT systems.
