!? I have already tried all password reset and recover Tricks with no luck!? And my DVD deck won't open. Please PLEASE HELP
SOURCE: i need factory reset for samsung propel
Remove the SIM card and turn on the phone.
Enter *2767*3855# or *2767*2878#
Hopefully, one will work.
Regards,
Waqar.
Note: All data will be lost in this MASTER RESET.
SOURCE: My nc10 reported the 'operating system not found'
Sound like your hard drive has crashed so bad that the notebook does not even know it is there. I would replace the hard drive and try to reinstall from external cd-rom . Make sure the external cd-rom is recognized in the bios settings Good Luck
Testimonial: "Thanks mate! "
SOURCE: How to Unlock Windows Vista Password?
I would like to introduce "Windows Login Recovery". It not only supports XP, 2000, and NT, I have personally tested it with Vista Home Premium and Ultimate. It works perfectly to reset any local user account to a blank password. I Wrote it to an old 128mb USB flash drive to recover windows password. Booting up and clearing a password takes a minute or two works like a charm. You can download it from http://www.windowsloginrecovery.com
SOURCE: hi everyone, I have got a panasonic KX TES824
First the button clear position
anfter press hold reset 20sec
it will reset
after turn off PABX
move the button to open position
and strat the PABX
Please let me know this is helpful
Testimonial: "Gulazarh4 is very active and willing to help out.. he is a guy who has patience and the "know how" to help out newbies in this field. once again thx"
SOURCE: forgotten administrator password of windows XP
For reset Windows Xp admin password,there are about three methods :
1.Use the built-in administrator account which you can logon without password in safe mode.It was built when you install your system and its password default as blank.Press ctrl+alt+delete twice in the welcome screen and you can see a classical logon dialog box,type administrator and press Enter.Or you can press F8 when you start/restart your computer to select start from safe mode.
2.Use a password reset disk If you have created ever.Of course it must be created for your current password.You can find a prompt when you input a false password in the welcome screen.Clik it and follow the guide.
3.If the two methods above cannot help you,you can find a recovery tool.As far as I know, there are many password tools on the network, but I have used is "Windows password rescuer professional 3.0" ,it is simple and safe that the average person will use it. It can soon reset the password in several minutes.Only four steps can help you reset the lost Windows password:
Step 1: Download Windows Password Rescuer and install it to another computer.
http://www.bestvistadownloads.com/software/t-free-windows-password-rescuer-advanced-download-smceigwe.html
Step 2: Run it and burn it to a bootable CD/DVD or USB flash drive.Before this confirm that you have insert a CD/DVD or USB.
Step 3: BIOS setting:Setup your own computer boot from CD or USB.Press F2 or DELETE when you start/restart your PC to get into the BIOS SETUP list.Use arrow keys to select boot manu,and use +/- key to move the CD/DVD or USB option to the first site.Then inset the CD/DVD or USB you have just created. Press F10 to save and exit.
Step 4: Reset Windows password: Wait for a moment,it will display friendly operate window,and you can reset whichever password on it.More detailed instruction refer to this article:How to recover windows xp/7/vista password.
Bypass eMachines password with recovery disks created before lost eMachine password
When input an incorrect password at the login screen, click "Reset Windows Password" and insert the eMachine password reset disk. The Password Reset Wizard will lead us create a new password to remove forgotten eMachines Windows 7 password.
Retrieve eMachine Windows password by DIY a password reset disk after forgotten
It is considered as the most instantly and easiest way to recover lost eMachine password. A .iso file, bootable CD/DVD/USB disk and accessible PC will solve problem within minutes without special techniques for a green hand on PC.
We can get the .iso file from many Windows password recovery programs. Just take one of the most popular tool - Ainorsoft Windows Password Recovery as example.
A. Download the suitable Ainorsoft Windows Password Recovery program and burn its .iso file into a blank CD/DVD or USB Flash Drive on an accessible computer;
B. Boot the burned CD/DVD or USB Flash Drive from the PC password locked;
C. Reset the new eMachines password.
Ainorsoft Windows Password Recovery tool concludes Basic, Enhance and Corporation versions. The Basic is opted for Windows 7, XP, Vista, 2008, 2003,etc. CD/DVD disk suits for it! The Enhance version can be used with USB disk for the former OS. While, the Ainorsoft Windows Password Recovery Corporation is designed to Windows 7/Vista/XP/2000/NT/Server 2008/2003/2000 with bootable CD/DVD or USB Flash Drive.
Main methods on eMachine password reset are shared as above. Recover forgotten eMachine laptop password from Safe Mode or unlock eMachines password with password reset disk. Hope the any one help our eMachines computer users!
Article source: http://windowspasswordrecovery.net/article/emachines-password-reset.html
If you have forgotten your password if you have another user account with administrative privileges you can log into that account and change your original user accounts password from the User Accounts applet in Control Panel.
If you dont have another account like this set up or dont have the password to it you will need to log into the built-in Administrator account.
In XP Home boot the computer into Safe Mode.
Do this by repeatedly tapping the F8 key as the computer is starting up.
This will get you to the right menu
Navigate using your Up arrow key the mouse will not work here
Once in Safe Mode you will see the normally hidden Administrator account
The default password is a blank
In XP Pro you do not need to go into Safe Mode
At the Welcome Screen do Ctrl-Alt-Del twice to get the classic Windows logon box.
Type in "Administrator" and whatever password you assigned when you set up Windows.
If you reset the built-in Administrator accounts password in Home or have Pro and dont remember the password there are ways to change the password for that account to a blank
hope this helps
