Possibly a free manual:
https://www.manualslib.com/manual/540113/Samsung-Ssc17web.html
Samsung SSC17WEB User Manual
SOURCE: Looking for a manual for A Samsung SSC security system
The link for ALL of the Samsung security stuff is:
http://www.gviss.com/Default.aspx?tabid=97
Pass it on......
fixemall......
SOURCE: Samsung B/W Observation System - Model# SSC-12
Same problem here after a close lightning strike. Fuse was good, main switch was operable. Noticed a charred spot next to a heat sink which has two diodes that appeared to be burnt. One being a zener diode, the other a simple diode. Gonna replace them and see what happens. Any suggestions?
SOURCE: I have a Samsung B/W
The vertical Ic either has bad connections or is defective. Look for a small flat IC attached to a heat sink with about 11 pins. Try resoldering the pins first. If that fails to resolve it, replace the IC. This IC may be marked LA7837 or something similar. If you are unsure, post the marking here and I'll confirm you have the correct part.
Dan
Am not familiar with an SSC-960, there are however SVR-960 (4 versions) by
Samsung.
Normally Samsung follows similar installation procedures and the differences in
their model are advance features and the length of recording time. If this could be of any help,
this link
is a users’ manual for a 1280 hrs model. It includes installation procedures.
Alternately you can try Google for “svr 960 pdf” but when I tried it most that
I can get are German language versions.
