Question about RCA F32650 32" TV
How hard is it to repair a failed flyback or horizontal output if you have never done it before? Or is it cheaper to buy a new TV? Model RCA F32650
  • 34 Answers
Its not hard to fix and repair if you know how to measure the exact voltage output.
Posted on Aug 03, 2009
6ya staff
SOURCE:
I have an F32650 and it wont turn on and also no sound. I also hear this clicking type sound coming from the rear of the TV.It sounds like it's coming from the right right rrrear of the TV.
Sounds like a probable shorted Horizontal Output Transistor (hot) Hopefully thats all. Sometimes the flyback will fail as well. If your not familiar with electronics I would recommend a tv shop repair. If its just the HOT transistor average repairs are 75-110 depending on your location.
Oct 17, 2010 | RCA F32650 32" TV
Find a horizontal output transistor or flyback
Flyback transformer part number for a tv RCA F32648
Mar 06, 2010 | RCA F32648 32" TV
I have a 1993 36 inch RCA, model # P46151WK. TV was on and suddenly heard something pop and it started to smell like something burned inside. It wont turn on anymore.
You may have a fried horizontal output transistor and a defective flyback transformer. If indeed this set is 17 years old.......cheaper to replace him...sorry!
Mar 01, 2010 | RCA F32650 32" TV
My rca tube tv has a high pitch whine when i plug it in no picture also
Hello you have a shorted Horizontal output transistor, also if you replace it also have the Flyback transfromer replaced also, these parts work in conjunction with each other, and if one goes bad its best to replace them both.
Dec 20, 2009 | RCA F32650 32" TV
Tv problem
it can be the flyback transformer and maybe horizontal output transistor. famous for that
bc
Jan 26, 2009 | RCA F32650 32" TV
RCA F32650 32" White lines with hazy white flickering
Absolutely right about the transistor and also check any adjacent resistors to the transformer and to the line output transistor. Good luck.
Sep 19, 2008 | RCA F32650 32" TV
Tv wont turn on
The green light indicates that it is getting power from the outlet ok.
The clicking is the power relay trying to turn it on but there is an internal fault forcing it to shutdown. You either have a power supply problem, horizontal output transistor (HOT) is shorted or a bad flyback transformer. In any case it can most likely be repaired by a qualified technitian. If it is the flyback it may be expensive.
Mar 10, 2008 | RCA F32650 32" TV
NO PICTURE
Adjust the two settings on the back of the flyback with a phillips screwdriver...
Dec 16, 2007 | RCA F32650 32" TV
RCA TELEVISION
Heres the fix for your set, replace the following 2 parts:
1) flyback transformer RCA part number 257805
2) horizontal output transistor RCA part number 237470
you must be proficient at soldering & un-soldering or you can`t replace these yourself, be advised that the anode lead coming from the top of the flyback transformer can carry a VERY NASTY shock if not discharged properly before trying to remove it from the picture tube, I`d strongly advise you to call a tech unless your familiar with this type of repair, BMW Rider
Dec 09, 2007 | RCA F32650 32" TV
32 in RCA MODEL NUMBER f32650
TV FINE UNTIL 2 NIGHTS AGO HAVE HAD 4 YEARS, STARTED HAVING A FOGGY SCREEN WITH WHITE HORIZONTAL LINES. HAS SOUND A FOGGY SCREEN WITH WHITE HORIZONTAL LINES. called retrace lines please check 1 screen control on eht transformer is mituned 2 supply to screen of crt 3 supply to rgb video output is absent 4 connector loose 5 crt base loose thanks
Sep 11, 2007 | RCA F32650 32" TV
RCA F32650 32" TV Logo
194 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
