We have a new console Mitel SuperConsole 1000 and we can not program wake up calls. How would I set up programming wake ups from the console?
Https://www.manualslib.com/manual/525349/Mitel-Superconsole-1000-Sx-200.html?page=74
http://edocs.mitel.com/UG/EN/9189-953-001-NA_2.pdf
Page 63
https://community.spiceworks.com/topic/2118453-mitel-phone-system-sx-200-superconsole-1000-no-wake-up-call-function
Mitel SUPERCONSOLE 1000 SX 200 User Manual Setting canceling Wake up Calls
SOURCE: Mitel superconsole 1000
Yes, there are things you can do to clear the locked out phone.
~ The locked means something is wrong with the phone -or- wiring to the room from the Mitel system...
Locked out is like leaving your phone off hook too long, you get that irratating beeping noise, then when the beeping stops, the phone is locked out to save power going to the set.
Ok ~ the first thing I would try, go to the set and play with it, hang everything up and test to see if you can get dial tone... the next thing is change out the telephone set, and test.
If you changed out the telephone set, and there is still a trouble, there maybe a wiring issue, in which case you will require a cable tech to test connectivity...
We have the same problem at our hotel.
You can't fix it at the console, you need to go to the room and unplug the guest's phone from the wall for 10 seconds... reconnect and it is fixed.
TO SET WAKE UP CALLS ON MITEL SUPERCONSOLE 1000:
Press FUNCTION key,
Press F5,
type room number,
Press F3,
Press F2, type time you want to set,
Press F2
(now on screen: you can see room number & wake up time. Means you did set wake up call successfully),
Press F1 KEY TO EXIT.
TO MAKE SURE THE ALARM HASS BEEN SET or NOT?
Press FUNCTION key,
Press F5, enter room number,
F3
NOW you can see room number & wake up time.
Press F1
TO CHANGE THE TIME FOR SAME ROOM:
Press FUNCTION key,
Press F5,
type room number,
Press F3,
Press F2,
type NEW TIME you want to set,
Press F2
TO CLEAR (REMOVE) WAKE UP CALL:
Press FUNCTION key,
Press F5,
type room number,
Press F3,
Press F7
Now on screen you will see Wk-Up1 = None That means alarm has been removed,
Press F1 to exit.
