Acurite model 822A2RX
SOURCE: dashes in my outdoor weather reading of Oregon Scientific station
The signals are not being received by the main unit. Try to reposition the unit or move it to a different location. Also make sure the antenna is in the clear and not next to any thing like a cordess phone or charger as these can make RF noise that can block or cover the needed signals.
SOURCE: My Nexxtech wireless weather station
You must move the remote sensor close to the base unit to reset it and it will work fine. After it shows the temp then you can move it back to its location. thanks for asking at Fixya.com.
SOURCE: I lost my manual on
I'm not entirely sure on make and model, but this may help :
http://www.ehow.com/how_7762570_acurite-wireless-weather-station-instructions.html
SOURCE: I cannot find the owners
You must remove the batteries in the base unit, replace them, and it should work properly. You can press the Tx button on the back of the remote unit to verify the RF reception. To ensure it is working properly, place both units next to each other indoors and make sure they read the same temperature.
The manual can be found here. Refer to page 3 for more information.
We would recommend a reset of your unit. Please verify that you are using good-quality, standard alkaline batteries such as Energizer or Rayovac, then follow the steps below.
1. Bring both the sensor and display unit indoors and remove at least one battery from each.
2. Make sure the A-B-C switch on both units match. Sometimes changing to a different channel can help.
3. Reinstall the battery in the outdoor sensor.
4. Reinstall the battery in the display unit.
5. Let the units sit within a couple feet of each other for about 20 minutes to gain a strong connection.
If you need any further assistance, please contact AcuRite Customer Support at 1-877-221-1252 or [email protected].
