SOURCE: software for compaq S200 color flatbed scanner
hi,
you should be able to find the drivers here choose your operatng system to download the setup file
cheers !!!!!
SOURCE: Cleaning the Flatbed Glass
We cannot clean inside the flatbed scanner glass, it is not a removable part.
SOURCE: Eversmart Scanner - Base Glass Recognition Process Failed
I have the same problem any fixes?
SOURCE: Fujitsu fi-5750c Flatbed Scanner need to
The back panel of the scanner should have a USB connection to the right of the SCSI ID selection switch (the farthest right on the back). Just get from any source a standard male/male A/B USB cable.
Then get the correct drivers here: http://www.fujitsu.com/global/support/computing/peripheral/scanners/drivers/twain/v921720c.html . Additional software may be found here: http://www.fujitsu.com/us/services/computing/peripherals/scanners/support/drivers-downloads_index.html
I hope this helps.
SOURCE: Can't remove the glass on my Canon 8000F scanner
What you will need
A - magnetic screw driver
B - glass cleaner
C - Flat blade dinner knife the sort that where around 30 to 40 years ago with the plastic ivory looking handles they have a round edge at the end that type
C - Patience
To clean the platen on the Canon 8000f
1. Take the lid off
2. At the bottom of the post holes remove the 2 small screws
3. Turn scanner over and remove the 2 screws underneath
4 this is were patience comes in and the flat bladed knife insert the blade at the corner and twist gently you will notice at the back centre 3 clips holding the black section of plastic in place the black plastic cover shoud pop off with gentle twisting of the knife blade
5. Whe the black plastic cover pops it's then a matter of sliding the platen backwards.
6. Clean glass with Amway Cryastal Clear or Windowlene
7. Then work backwards to replace the parts magnet screw driver is a help here.
8. Done
9. I figured that if you break the tabs being a bit to heavy handed don't worry because its held in place with 4 screws and the way the plastic is designed
10. Patience is the key as well as those plastic clips at the back.
11. Oh and don't forget to unplug it first
12. A nice clean Scanner
13. Had a problem with loading the latest software from Canon (Win7)drivers it would load and then run but would then disappear, Toolbox 4.1 won't load when you use your disc, I'm not sure what I did but I eventualy got the Toolbox 4.1 to load from the disc by finding the application on the disc and running that, it seemed to be hit and miss because I tried several times.
Chris Moore - Sevenoaks Kent UK
