Steps to follow in connecting Canon ip7240 Printer to Wi-Fi:
Step 1: Printer must be switched on.
Step 2: Hold and click the Wi-Fi button for a few seconds on the front of the printer.
Step 3: By pressing the button you must be sure of blue flash and then press[ WPS] button within 2 minutes.
Step 4: For exact details of the WPS button, refer to the access point manual.
Step 5: Blue light keeps flashing while searching or linking to the access point. When the printer connects to the wireless network, the blue light stops flashing and stays illuminated.
https://www.canonprintersupport247.com/blog/how-to-connect-canon-ip7240-printer-to-wifi
Https://www.printerknowledge.com/threads/how-canon-ip7240-wate-ink-reset.8741/
http://translate.google.dk/translate?sl=auto&tl=en&js=y&prev=_t&hl=da&ie=UTF-8&u=http%3A%2F%2Fwww.druckerchannel.de%2Fartikel.php%3FID%3D3433%26seite%3D1%26t%3Danleitung_zum_wechsel_des_ink_absorbers&edit-text=
How Canon Ip7240 Wate INK Reset
SOURCE: canon multipass f80 waste ink tank
First off to do it will take you about an hour, cost you between 10 to 30 dollars. The best alternative is either take it to a Canon Dealer and pay 40.00 and don't worry if you break the seal, or I will tell you how to reset it so that it thinks it has no ink. DO NOT PLAY WITH THE OTHER SETTINGS OR YOUR PRINTER MAY NOT WORK AFTERWARDS.
This works on the F30, F60, and F80.
Resetting the Waste Ink Volume Counter
1) Enter SERVICE MODE.---
By pressing Menu-Copy-#
2) Select TEST MODE.
3) Select [8] PRINTER TEST in TEST MODE.
4) Select 3. [EEPROM CLEAR].
5) Select 0. [INK COUNT].
6) Press the [OK] key.
7) Press the [Stop/Reset] key (returning to the state of 3)), and then press the [ON/OFF] key.
Skip step (6) since there is no [OK] key on F30 printers.
SOURCE: waste ink tank full error 5b00
Check out:
http://www.fixyourownprinter.com/forums/inkjet/50418#1
normally, the logical solution is to replace your waste ink tank, but I have tried a solution which could make your canon printer function again.
Try this: With your printer turned ON, press and hold the I/O
switch then pull off the power cord. This will turn off your printer.
But without lifting your finger on the I/O switch put back your power
cord. the I/O switch will blink for a second and will go off, then
turn-on your printer again and see if it works.
SOURCE: The waste ink collector/tank is nearly full
The ink collector should be found underneath where the cartridges normally rests. Put some tissue paper on the ink padand let it absorb the ink. You might have to repeat the procedure a few times to get rid of all the ink.
SOURCE: Canon PIXMA iP3000 waste ink tank showing nealry full..
Follow this procedure:
1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not, press the Power button once more.
8. Your printer should respond as normal.
