I don't need help with insurance. I need to know how to reset my scanner ( Whistler 1010I don't need help with insurance. I need to know how to reset my scanner ( Whistler 1010
You can't post conmments that contain an email address.
Hi there's this website something like reliable-store and it is very amazing for manual for repairing servicing anything
someone on fixya recommended it to me and I thank him even today
They have full manuals and it's verrrrry cheap and mine
I got free in offers
3rd time I also had an issue with the file so the girl replaced it in 30 mins
there is one more but i don't remember its name it was 2 years back bitman something link this
Try it out brother
Resetting the Scanner
If the scanner's display locks up or stops operating properly,
you might need to reset the scanner.
CAUTION: This procedure clears all the information
you have stored in the scanner. Before you reset
the scanner, try turning it off and back on to see if
it begins working properly. Reset the scanner only
when you are sure it is not working properly.
1. Turn off the scanner.
2. While holding down 2, 9, and Hold, turn on the scanner.
It takes about 3 seconds to initialize and CLEAr appears.
If all else fails, and it sounds like it has, you can RESET or INITIALIZE the scanner to bring it back to normal operation.
To RESET: - Power the scanner OFF - Power the scanner back ON - Insert a pointed object (paper clip, penpoint, etc.) into the RESET hole on the back of the scanner - Gently press and then release the RESET button inside the hole.
NOTE: RESET will NOT erase the data that you've programmed into the scanner.
If RESET doesn't clear the problem, you can carry out the more drastic INITIALIZE process.
- Power the scanner OFF - Power the scanner back ON - Press 0 after the scanner completes its boot routine - Press 1 after the menu appears - Press ENT
DO NOT power the scanner OFF until the INITIALIZE process is complete (M000 and Bank 0 Ch 00 appear on the display). The INITIALIZE procedure will reset the scanner to original factory settings and erase all data that you have programmed.
If all else fails, you can RESET or INITIALIZE the scanner to bring it back to normal operation.
- Power the scanner OFF - Power the scanner back ON - Press 0 then 1 while "Welcome to Dual Trunking" is displayed. - "Initializing Please Wait" will appear for about 2 seconds.
DO
DO
DO
If all else fails you can RESET or INITIALIZE the scanner to bring it back to normal operation.
DO
