The camera wont turn on. I hear 3 beeps when i press the on button. The zoom is extended and the lens is open.
My camera wont turn on or off, the lens is stuck halfway, so i cant pull it, and i cant tell my mom or she WILL kill me.
oh nd i dont have a warranty.
A temporary fix to power up is to press the menu and power button at the same time. When the lens is extended and it beeps, on my camera , the lens is *stuck* Give it a gentle tug , then try the power button again. I discovered this *TEMPORARY* solution on the web. I was able to *close* the lens and shut the camera down properly. I would suggest either seeking warranty ( if possible) or taking it to a camera repair shop. That is what I will be doing. Good luck fellow shutterbugs!
I have the same problem. My lens is extended and I ever tried to wiggle the lens a little, as that usually will work. Today, my camera shut off with the lens extended and the camera will not even turn on. I got this camera last Christmas, so it hasn't even been a year. I am very disappointed about this.
exact three beep problem
Same problem...
Exactly the same problem, thanks for the suggestion, but no dice.
I won this camera from a radio station so I don't have a reciept. The camera powers itself off but the lens stays out. I've tried different batteries.
Anyone had any luck with an exchange?
My lens is out and the power is off and i tried holding down menu and the power and all it did was made things worse. I just got this camera like last month and if my parents ever see this im like so dead!!!! HELPPP!!!! PLEASE HELP ME FIX THIS!!!!!!
Same problem after about 1 month usage. Suggested solutions doesn't work. Very poor Samsung :(
EXACTLY THE SAME PROBLEM!!!!!!
My camera works when I don't use a SD card, when I use it, the camera won't turn on and the zoom stuck open! After 2 second the camera turns off with the zoom out and I can't turn it on again without removing the card...
