SOURCE: Manual J Calculations for Residential house 1018 sq. ft. American Standard unit
without actually doing a load calc it would just be an educated guess.Good choice in equipment though.
SOURCE: The other day. my American standard air
Yes, that might be the problem but in this case you need a qualified technician to test system and find real cause of problem.
SOURCE: our allegiance 12 quit working does it have a
no reset button,check the breaker,or dissconnect by the unit,fuse could be blown.
SOURCE: Inside Electric Furnace/Air Handler Not Working. Please help!
ok this can be simple or tricky is the breaker that trips the same size as the one in the breaker panel 2.look in the unit itsself see if there r breakers inside the unit there usually are and they might have tripped it might be as simple as flipping a breaker but the problem with the breaker tripping is what concerns me now it may just be undersized or getting weak and finally crapped out get ur meter and flip the breaker on and see if u r getting power to the unit if ur not u have gott a breaker that isnt letting power go thru now if u have power u might have a bad blower motor turn the unit on and calling for the fan on if the fan doesnt start try spinning the blower by hand now if it starts then u probably have a bad capacitor they r usually mounted on the side of the blower housing it is oval and its gonna be a 5mfd(microfarad) or 7.5mfd and that couldve been what was kicking the breaker now if the blower is stuck and it wont turn or its very hard to turn then make sure the blower wheel hasnt slipped on the shaft and is rubbing up against the housing if it is just loosen the set screw and set it back even and tighten it back up now if the wheel is free and its still hard to turn then u have a bad blower motor its not a big deal to change out and not real expensive if this dont help hit me back and well walk thru it hope this gets lil momma and the pets warm have a good day
SOURCE: American Standard Allegiance 13 A/C Maintenance
Turn off the power and then use the garden hose to clean out the dust and grass.
Testimonial: "Thank you jumptrout51 for your information. I'll try this out."
Have you looked at the filter in your furnace? Did the inspection report state that they ran the A/C and if so what temps were they getting? Is the compressor and condenser fan running when you have it in cooling?
with a thermometer, measure the supply air vs the return air. 13 degree difference passes inspection in my area but we like to see a 17 to 20 degree difference. Keep us posted
