SOURCE: how to remove chuck from drill press
I just looked at a breakdown for this tool and it is not that clear. But to get an owners manual you can go to Searspartsdirect.com and type in your model number and look at the same schematici I did and also order a manual for about 7.50. Usually though on a drill press like that it would be a morse taper. Do you see a slot cut thru the spindle on both sides, if so there should be a tapered key that came with the unit. In that case what you would need to do it put the key in the slot and tap it with a hammer to remove the adaptor and chuck. Let me know if I can help further
SOURCE: Replace drill chuck on 23 year old Craftsman 8" drill press
Yes it does have a Morse taper and you can remove it by gently hitting it with a rubber or nylon mallet.
SOURCE: Mastercraft seized up chuck
being that new, it should not have seized up, all you can do is try spraying wd40 into the chuck between the teeth and mandrill. if it doesnt work, replace the chuck, it is fairly inexpensive
SOURCE: hi, I have a Clarke Drill Press Model No:- CDP 12HBN
You can get a universal chuck key at Home Depot, Lowes and many other tool outlets. They have 4 different keys in one.
SOURCE: need to replace chuck on 1/2
took off the old chuck , measured, and took it with me to purchase a new one.
