Go to Homebase, B&Q, Ebay or your local hardware shop and buy a new spool, ALM part number BD032.
SOURCE: threading line on black & decker GL301 strimmer
Do you mean that the string keeps feeding as you try to operate the trimmer?
If so, you are winding the string on the spool the wrong way. Put the string on the spool in a clockwise direction. This should do it.
Jim
SOURCE: How do you fit a new spool?
refer to here for generic instructions of replacing the wire/string on a trimmer.
http://wiki.answers.com/Q/How_do_you_replace_a_weed_eater_trimmer_line
have a read through, it may help assist you.
SOURCE: B & D auto feed string trimmer won't advance string
Is the string spool seated on the rachet correctly? If so and all is well, it is worth noting that these trimmers auto feed fuunction is problematic at best, requiring manually unwinding some line every few minutes as the unit gets older.
SOURCE: how do i rewind the
When you pull off the spool it will have arrows embedded,
on the spool to show you which direction to wind it.
good luck!
ensure the spool is not ended if so replace with new spool of string. also check the retaining screw in the middle is not too tight. undo it one click at a time to alow the spool to unwind when the motor runs
always disconnect your strimmer from the power when doing this also wear protective footware and long trousers, when using such tools.
