SOURCE: Harmon Kardon Sound Sticks
Hello there
First things First:
1) check cables, and the input cable to your PC.
2) Check for right voltage, may be somethings is chargind a lot**
3) Power regulator on the Speakers is damage.
4) RMS your Spks, for replace. or warranty.
5) try in another computer. ( if apply)
SOURCE: HI, I just purchased a
Connect the optical audio OUT on the TV to the optical audio IN on the receiver. Turn the receiver on and set it to input as it was labeled on the connection ("video" or "auxillary" or such). Turn the TV on and set it to an active TV channel (with video and presumably audio info), not to VIDEO 1.
If you continue to have a problem, please provide an update.
SOURCE: Harmon Kardon unlock error
I have the same problem. All of a sudden no sound through my TV connection (but through the DVD connection the sound was still working). I changed the connection from video 1 to video 2 and got the sound back. It is not a real solution, but a practical one :-)
SOURCE: How do I disassemble + clean Harmon Kardon SoundStick subwoofer?
Check for a Fuse. Mine is an older model and has a Fuse right next to the power cord. It probably has a slot for a flathead screwdriver.
SOURCE: Installing a Harmon Kardon on a 03 Ultra
The 23 pin main connector is a direct plug in from the 03 bike to the HK unit. The only issue would be if the original 03 was using the accessory connector as well. The accessory connector on the 03 is another 23 pin. It's a 35 pin on the HK. For more info, or to discuss this further, contact Iron Cross Audio (www.ironcrossaudio.com)
IMPORTANT NOTE: If the AVR's video output resolution
is set higher than the capabilities of the actual connection,
you will not see a picture. If the best available video connection
from the AVR to the TV is composite video, press this button
and change the resolution to 480i.
