SOURCE: Shark euro-pro x upright vacuum that shuts down every 15 minutes
These are prone to overheating. The manufacturer put a foam 'filter' wrap around the electric motor. This filter wrap insulates the motor, trapping heat inside, which causes overheating. The motor is very similar in form and function to the one in the Hoover Windtunnel, but the Windtunnel has no filter wrap. It doesn't overheat, and functions fine without it. There is a filter on the intake anyway. It's a redundant filter, and I have removed mine. It works fine now.
If you take the filter out yourself, you will need a special screwdriver for one of the motor cover screws. I guess they don't want the consumers opening it up.
I suggest taking it to a vacuum repair shop and explaining to them the problem, and asking them to remove the filter wrap from the motor.
SOURCE: my boss model 5892 brush will not roll
This unit has a reset button on the side of the hood. Recline handle, turn power switch on, pressing down in carpet mode, press reset buttonon the side of the hood, the brush should turn on.
SOURCE: Shark SV736R motorized brush won't rotate
The 2 metal pins of the motorized brush are not in contact with the vacuum cleaner. or the Motorized brush is clogged up. You have mentioned that it is cleaned, but still give a thorough inspection. For the metal pins, firmly insert the motorized brush into the air-intake nozzle. This will connect the motorized nozzle to the unit power supply.
SOURCE: brush roll won't turn on
Atthe bottom of the vacuuam are screws to take off...two of them are near the rear wheel assembly....two of them are behind the front mini wheels (just pry the front mini wheels so that they pop out...they pop back in)
Remove all of the screws. Remove the bottom from the top..they come apart in two pieces. Ceck the belt on the bottom piece. Slide the roller out starting from the end opposite from the motor end. With the roller off, slacken the the belt so that it misses the gear on the motor (you will have to hold it with your hand). Plug in the vacuum. Turn the power on to the roller on position. The motor should work and the green light should be on. If the motor doesn't work, then it is defective. If it does work, turn off, unplug and shoot the gear and the two ends of the roller with WD-40. reassemble. good luck.
