Air Tools & Compressors Logo
R
Ray Clark Posted on Aug 20, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a Sears 2 HP 20 gallon air compressor, model number 106.170641, currently wired for 220. Can it be converted to 110 ?
Steve Pack
Level 3:
  • HP Master 7,121 Answers
  • Posted on Aug 20, 2018
Steve Pack
HP Master
Level 3:
Answers
7121
Questions
Helped
2271681
Points
27886
It is a 5 hp motor and 15 amps 230 , rewiring it would require 120 vac breaker rated at 60 amps. The power would have to upgraded to #10 AW there is is no receptacle available, so the answered is no. . the the answer upgrade to 220 Vac
3 Related Answers
John Trevino
  • 1420 Answers
  • Posted on Nov 27, 2008
SOURCE: converting from 220 to 110 volts
Most brands of air comperssors are built to work on either 220 or 110 v. I believe that 220 v compressors are more efficient and draw less current and run cooler.
The more expensive compressors have a switch allowing for voltage selection. Still others will have a wiring diagram printed on the motor allowing voltage change by changing jumpers. Most all of the sears compressors that I have repaired were of single voltage with no other way to change except change motor. Do not worry however, you have the better motor. It is easier to convert the outlet plug to 220 by isolating the circuit and installing a 220 v breaker. enjoy
Anonymous
  • 2926 Answers
  • Posted on Jan 18, 2010
SOURCE: i need to convert my 220 wiring back to 110 on my
There should be a plate where the ires run thru, and on the plate or motor itself, there should be a diagram shouwing what terminals to connect the leads too.
Hope this helps.
W.L.
  • 2511 Answers
  • Posted on Jun 26, 2014
SOURCE: Converted from 220 to 110 voltage
Have a look at the rating plate, it should state if it's dual voltage, if so there will be a movable link under the rating plate or somewhere obvious. If it isn't dual forget it, the wattage precludes using a ballast
Have an old (1977) Sears 2 hp, 20 gallon air compressor. It is wired for 230 volts. Is it possible to rewire it for 115 volts ?
you'd have to change the voltage regulator, which is usually inside the motor - on newer motors, if they have a separate Power Supply, you can sometimes change it on a slide switch... keep in mind, that 230 is MUCH more effective for a device made for drawing a lot of power - that motor might draw 8-10 amps at 220, which will be 2x that if you go to 110... so, when all is said and done, it might work out cheaper to just spend like $200 and buy a new 110 unit that is similar... but again, depends what you want to use it for...
Century motor wiring diagram for 8-152863-01 motor
You can\'t run it on 220, but if you take only one of the 220 black wires and attach it to the black on the compressor you are feeding it 110. The problem will be that you have no neutral wire so you\'d have to use the ground of the 220 lead (green) as the neutral on the compressor (white). It\'ll run fine but it\'s not the right way and it can be a hazard. The white wire is neutral which is basically a ground wire from the electric company, the green is the ground wire in your building and it\'s there for safety so using it to power things is dangerous and probably illegal. I\'ve done it in a pinch, but wouldn\'t do it if at all avoidable. You may be able to get a transformer but you\'re probably better off running a 110 circuit or getting a 220 compressor.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/oscar_403cc49e0f00cda7
I need to convert mu Puma PPH 30-10 air compressor from 220 Volt to 110 Volt wiring, but I do not have the owners manual or a wiring diagram for it. The Motor is a GE
If this is a 3HP I don't think you can switch it. However there is usually a wiring diagram under the square box on the side of the motor.
Need a manual for sears model 919.152930
There are manuals on this page, they might not be the model you want but they may help you to convert yours. Just scroll down the page http://www.about-air-compressors.com/sears-air-compressors.html
1helpful
Husky 60 gallon compressor switch from 220 to 110
Try here, very good for asking problems http://www.about-air-compressors.com/husky-air-compressors.html
Have a husky 19 gal 1.5hp it kicks on when first start to work and when it builds up air and i use it and when it wants to kick back on it wont i have to wait till it cools down.
Is there an option for you to run this compressor on 220 volts vs 110 volts??? If so, you may want to convert it by following the re-wire instructions on the motor or wire access plate/instuction book. The reason your compressor won't fire up again after building pressure is the head pressure is to great at restart and 110 household current is not enough to give the power needed to turn the piston. You'll need to replace the plug and have someone run a 220 volt circuit once the conversion is completed.
I need to convert my 220 wiring back to 110 on my sears air compressor model number 106.173841 with doerr electric motor model 600678.
Hope this helps.
Compressor causes 20 amp breaker to trip.
If I did the math correctly, 5.5 HP is right at the boarderline of 20 amps, particularly for an older machine that has some deteriorating electronics.
What to do? Can you reconfig the motor to run on 220 Volts??? It would then run on 1/2 the amps.
If you have a dedicated 120 line for this compressor now ... all you have to do to change that to 220 is change the breaker (I presume you have a vacant slot to do this). Find the "neutral" for that wire (white) ane make it the "red" for your compressor line ... (and mark it as such for your future behefit) change the outlet from 110 V 20 A to 220 V 20 A. Both lines will run on #12 with G wire.
If you dont have a slot, you could change one of your standard slots to a "piggy back" remodeling style breaker (has two breakers in one slot). This will free up one slot in your panel for the new 220 (double pole) breaker.
Let me know what you think
Thanks for using FixYa.com
Positive comments appreciated
a
2helpful
2answers
Sears 5 h.p. air compressor model 919176850 convert to 110 volt
pull the cover where the wiring goes into the motor, usually there is a wiring diagram on the underside. If not, go to sears online to see if you can get the manual for it
2answers
Converting from 220 to 110 volts
Top HP Air Tools & Compressors Experts
Ngoro
john h
rodder98
Level 1 Expert
Are you a HP Air Tool and Compressor Expert? Answer questions, earn points and help others
