There are many possible reasons. Few pointers.
Disconnect antenna and check for static. If it is still there then turn off everything on boat , including battery charger and check for static. If is gone then start turning on electrical devices to narrow what is causing electromagnetic interferencw. If your still have static then disconnect all speakers right on stereo harness. Start connecting speaker to individual output to check for static. If there is no static then one of speaker wire installed on boat is shorted somewhere. If you have static when connecting speaker straight to stereo harness then likely internal ampflier inside stereo is a problem
SOURCE: Turning on my Lowrance LCX 111HD fish locator creates static with my ICOM M502 VHF Marine radio.
Hello LJones0455. From your detailed attempts there are few options. Position the transducers one foward one aft. Connect the negitives of the battiers to the boat still route both positive & negitive wiring to all devices. Check the continunity of your transducers include flexing while ohming. Let me know of the results.
SOURCE: radio shows on but no sound to speakers
I flooded my Eclipse and the AMP is under the passenger seat. Might have got wet and ruined it. They are expensive from the dealership ($900). Try a junk yard.
SOURCE: What is the input to the tele mute wire? Can I use a switch?
this wire is used for cell phone mute when you have a incoming call thats it. just cap it off and leave it
SOURCE: wire mike to browning cb radio
1)white
2)red
shell) black and shield.
If radio keys up as soon as you plug the mic in switch the red and black wires. Good luck
Dan
SOURCE: getting a lot of static on speakers of my wave
not nessarrly
could be as simple as a bad entena
try moving the radio to a new location
