Question about Power Washer Garden
My electric power runs for a few seconds then shuts off. If I remove the power nozzle the engine works with the open wand. How can I get it work
It is an earthwise 1650 psi
  • Power Washer Master
  • 2,824 Answers
Check all ends of your power wand. there should be a little filter and if it gets plugged the motor will shut down. Check both ends of your wand. The sprayer end should come off and mine has a filter if you take the sprayer end off.
Posted on Aug 20, 2018
Anonymous
SOURCE:
Anonymous
SOURCE: troubleshooting reddy heater 115,000btu
runs for awhile shuts down with a big puff of smoke comes out poured diesel 911 thought i had water in diesel fuel cans nothing help need solution ASAP
Posted on Jan 18, 2009
Anonymous
SOURCE: Need replacement steam wand sleeve
http://saecooutlet.com/ has parts and help for the sirena machine
Posted on Feb 11, 2009
Anonymous
  • 10 Answers
SOURCE: pressure washer stalls out when wand nozzle is released
common for not starting unless trigger engaged as you are turning the pump as well as engine creating pressure,as for stalling pump has unloader valve which is probably in need of grease(use good silicone grease)this allows water to ciculate when trigger released.
Posted on Apr 20, 2009
Anonymous
  • 104 Answers
SOURCE: Karcher K 3.68M Electric Pressure Washer. Wand trigger Locks Up.
Sounds like the pressure valve is broken thats why you cant depress the trigger , the valve is on the pump , i would suggest taking it to a repair shop as they are fiddly things to fix
Posted on Jun 05, 2009
Martin Grech
  • 94 Answers
SOURCE: Motor does not shut off when trigger on wand is released
When the trigger is released, pressure builds up and this acts on a valve (spill valve or pressure control valve). When this pressure is big enough it will push the spill valve out and closes a micro switch. Now this Spill Valve gets stuck sometimes, mainly due to soap and chemicals...so the micro switch is not closed...so the machine contiues running. If this is left likee this it will cause damage to the valves. So all one has to do is service the spill valve or as I usually do I replace it. There are cases were the micro switch is damaged also..and needs to be replaced. To see the spill valve and micro switch you must open the cover. The spill valve is located where you see a cover with an electric wire coming out of it. If the micro switch is good...you must tackle the Spill valve.
Regards,
fulltech.
Posted on Jul 28, 2010
Testimonial: "Makes sense!"
What the difference between snow blower earthwise model sn71018 and sn72018
The joker in me wants to say '1000.'
They appear almost identical in performance in this comparison.
Compare The Earthwise SN71018 And Earthwise SN72018
Dec 09, 2017 | Garden
Why won't the hose connect to the washer?
The connection is made at the bottom of unit.
should be standard garden hose.
sometimes I find if I gently hold hose against connection point then rotate counterclockwise until I feel a click! then ( without lifting hose) rotate clockwise and hose should now be threaded onto power washer.
Oct 09, 2016 | Earthwise 1850 PSI Electric Pressure...
Where can I buy a rectifier for a 15 amp earthwise lawnmower
Hello Condo Sarto,
The first site that popped from an internet search...
Sears Parts...
searsparsdirect com
Jun 27, 2016 | Electric Earthwise Corded Lawn Mower...
Pacifichydrostar 1650 pump pulses when pulling the trigger
It may be time to do mainatance to it. Look at: http://www.manualslib.com/manual/443079/Pacific-Hydrostar-1650-Psi.html?page=14
for information on that. It is also possible you do not have enough water flow to the pump. Be sure your feed hose is not colapsing.
Sep 21, 2013 | Plumbing
HOw to attach soap bottle to earthwise 1850 pressure washer
It should have a tube on it put it in your bleach bottle and use the black tip for dispense 1/2 bleach/1/2 water
Aug 08, 2013 | Earthwise 1850 PSI Electric Pressure...
Mower started smoking, then stopped working.
Try to see if there is any oil in it. Or maybe your belt is clogged. A good cleaning and maybe a change of plug may help.
Mar 01, 2010 | Electric Earthwise Corded Lawn Mower...
Husky 1650 PSI power washer hose got brittle and broke.
If the $$ that you Husky Dealer is asking is to tall, try a garage that make brake hoses. Take the hose with you and many times they can remove your nozzle and install it on a new piece of hose. MAKE SURE that they understand that this hose is for a pressure washer...DO NOT use just any hose...it MUST be a high pressure rated hose.
Oct 07, 2009 | Garden
Where can I buy a bag for this mower
Go to www.precisionope.com and order one.
Good day.
Oct 04, 2009 | Electric Earthwise Corded Lawn Mower...
Garden Logo
62 people viewed this question
Top Power Washer Garden Experts
ray gallant
STEVE
Tom Chichester
Are you a Power Washer Garden Expert? Answer questions, earn points and help others
