Car Audio & Video Logo
D
David p Bohren Posted on Aug 19, 2018
Alpine IVE W535HD Lost power, won't turn back on after removing the removable faceplate. Checked fuse under hood.
5 Related Answers
Dalynn Turner
  • 346 Answers
  • Posted on Feb 11, 2009
SOURCE: alpine 7835 display lights not working, everything else is fine
if it's not under warranty, I would advise taking the face plate apart and checking for burned spots on the board and using compressed air to remove anything that is conductive that may cause a short in the face plate. The face plate should be really easy to take apart.
Anonymous
  • 113 Answers
  • Posted on Sep 15, 2009
SOURCE: how do I remove the drivers front fender of a 1994 Dodge Ram 2500
yes undo your battery as ans air bag has a connector on the seat and if unplugged could cause air bags to go off with battery still hooked up leat sit for five min. should be four bolts or nuts holding seat down
johnjohn2
Johnny Brown
  • 5763 Answers
  • Posted on Oct 08, 2009
SOURCE: my horn isnt working. we checked the fuses but nothings working
check and see if you have power at the horns, mostlikly you have bad horns,usauly thats what happens horns brun out and pop the fuse, il bet horns are bad. good luck.
Anonymous
  • 3 Answers
  • Posted on Dec 06, 2009
SOURCE: Kenwood KRC -X858 Faceplate/Power Problem
I have the exact same problem. I called the tech line and the tech reported that the ribbon cable is probably broke. It is the flex cable between the head unit and the rotating face plate. He said it's not an expensive fix but we would need to mail it to a service center if you're like me and not near one. I just replaced mine with a new unit. It was about time anyways.
Anonymous
  • Posted on Feb 05, 2010
SOURCE: ELECTRICAL PROBLEM, KEY STUCK, FUSES BUZZING
step on brake put transmission in neutral turn steering wheel a little to take pressure off ing. turn key
No sound rom the speakers. removed radio and checked wiring harness and checked the fuse under the hood and they are all ok. what can I check next?
These units are prone to problems... get a good aftermarket one from Crutchfield on-line with the faceplate adapter... it will be easy to install and look factory.
IVE-W535HD
i have the same issue. if i find out later today ill respond back on here. calling best buy "geek squad"
1993 buick park avenue heater won,t work.checked all fuses an relays
i beleive you did more than that.? you,ll probably find all have a common earth , chech and remove it , clean with a wire brush and replace, also chance the fuse you removed and replacer reguardless of it,s appearence , ensure its put back in the correct location,peter.
3helpful
2answers
Removing the fuse box under the hood to check for wire shortages
Try running both wires from battery ground and hot dont spin over more than likely the fan motor itself is burnt up.
2002 intrepid 2.7 Im getting no crank from the starter and I dont hear the fuel pump kicking on when the ignition key is turned on, I do get power to the radio and dash, Ive checked fuses and replaced...
Under the hood, there should be a fuse block. Remove the cover and there will be a 20amp(i think) fuse that protects the fuel pump and starter circuit. I've run into this problem many times and every time it ends up being the starter that blows the fuse.
My cda-9813 wont power on,how to take of faceplate?
Here is a link to the owner's manual for your stereo, it shows how to remove the faceplate:
http://a248.e.akamai.net/pix.crutchfield.com/Manuals/500/500CDA9815.PDF
2answers
My display stays on for about 3 seconds then it turns off until
If this model has a detachable faceplate,
Remove the faceplate and clean down the contacts with metho and a cotton bud.
Over time usually corrosion and dirt etc builds up on these terminals making them loose cotact when you touch the faceplate.
This is the most commonly known problem alpine units.
Other common problems is the power supply failing /amplifier.
Hope this helps you out
Cheers
Steve
Car stereo and car remote not working
Definitely check all the fuses. Even the ones under the hood.
Top Alpine Car Audio & Video Experts
xxxxxx xxx
ZJ Limited
ZJ Limited
Steve Sweetleaf
Steve Sweetleaf
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
