SOURCE: konica 7020
Did you blow it up, probably not.
Click this link for the everything.
http://www.kmbs.konicaminolta.us/content/support/supporthome.html
Or click on this link for the specific manual.
The error codes you seek are not in the manual, you'll have to call Konica to tell you what they are ... call Konica at (860) 683-2222.
Hope this helps. Rate a fixya!
SOURCE: Fujitsu M4097D error about Front side optical alarm
HI,
I work on the fujitsu scanner hotline. This message means that the optical unit needs to be replaced, there will be very little you can do to fix this problem.
SOURCE: problems with internal
Then its probably dealing with yahoo messanger! Uninstall the program and re-install it! That should do it, if it dosnt, check for viruses, you may have a program containing a virus!
SOURCE: Problem Event Name: APPCRASH Application Name: iexplore.exe
Try Firefox: http://www.mozilla.org/firefox
SOURCE: Overload LED lit, constant warning tone, no load
I have seen this caused by a defective battery. Disconnect the battery and reconnect to AC and see if the overload symptom disappears.
Lou
