SOURCE: Bobbin winder is only thing that works
What model are you talking about? For my older Husqvarna machine you had to pull the bobbin winding bit out to wind the bobbin, then push it back in when you were done.
SOURCE: Janome Memory Craft 4900 QC
its the sensor on the bobinwinder who are loose. If you are handy. you can remove the top cover of the machine.
And on the left side of the bobinwinder you will find a micro switch. Probably you have to tighten the screw on it..
SOURCE: Top & bobbin thread will not sew
Most likely the needle is in backwards. Weird I know, I have no idea why but if the needle is in wrong, it either hits the bobbin and breaks or won't grab the thread at all. Good luck.
SOURCE: bobbin problem
Remove the race cover and jiggle it out. It is only stuck in there with thread.
O
oil the machine first. Then, determine whether or not you need any parts at all.
SOURCE: machine does not sew- it does not catch the thread from bobbin
The timing mechanism is likely off. Take off the plastic bobbin case and see if the eye of the needle, on its way up, is just below the metal hook that catch the thread. If not,open the bottom cover with a flat screwdriver, loosen the two 2 mm hex screws, push out and disengage the gears. Adj the hook position by turning left or right so that it is right above the eye of the needle when the needle is on its way up. Tighten the hexes. I also give my machine a good old job with a high grade geese on the gears and light old drop on all moving parts before I close the cover.
Have fun.
