SOURCE: wont fill with water
Clean the floats inside the wash tank. If they get fouled, they will "trick" the machine into thinking it already has water in it
SOURCE: bof error hobart amx
Sorry so late for the reply.Im a hobart tech and i dont recall this model of your unit,are you sure the model isnt a am-14 or am-15?
SOURCE: Dish washer over filling?
The first thing you should do is clean the level probes in the unit. There are two probes sticking through the back of the unit and the water completes a circuit between these two telling the machine when it is full. If they are clean, you may have a faulty sensor or wiring.
SOURCE: Bosch dishwasher---water filling from the bottom when off?
i would replace the inlet valve. it sounds like it is not closing all the way
