Question about Canon Cameras
My canon SX210 IS - The start up sound, beeps when it focuses and noise when you take a picture is not work every time. What is loose? Just replaced the screen & back light. Everything else seems ok
6ya staff
SOURCE:
Anonymous
  • 104 Answers
SOURCE: Beep - Beep - Beep - but No Picture
1. If the camera can not focus on a subject, or can not determine the appropriate exposure setting, the camera will beep and disable the shutter button. This is to avoid improper processing of the image. This is usually due to either poor lighting conditions or movement. 2. The camera Flash Element requires ten seconds to recharge between images. Although the camera is ready to continue capturing images almost immediately in bright (daylight) settings, if you are using Flash photography the Flash element will need to charge between shots. If you try to take a picture before the Flash is charged, the camera will beep and disable the shutter button. Once the Flash unit is fully charged (10 seconds), the camera is ready to continue. 3. The batteries may be running low. LCD Display, Flash, and Playback use much more power than taking pictures. It is possible to quickly consume battery power, even if you are not taking many pictures. Try turning the Mode Dial to the OFF position to recycle power. If the camera beeps and will not take a picture under normal conditions, you may need to change batteries.
Posted on Sep 11, 2005
Anonymous
  • 3130 Answers
SOURCE: Canon MV700 Mini DV Digital...
NAAAA all of my years I have never had a ccd open up where you got no picture at all!! Most of the times its a small line or discoloration or a pixle or a group of pixles out. The most common problems with a camcorder that has no picture on the camera is a stuck shutter or iris. you can turn on the camcorder and tap on the lens around the middle and sometimes it will open up. now if this fails then you have failed capacitors in the camera section and most of the time it dosent pay to repair as the entire board has toi be replaced. sorry windman sorry silly girl.
Posted on May 10, 2006
Anonymous
SOURCE: No picture or sound
sounds like the PTV Small Signal Board.
Posted on Aug 02, 2007
Anonymous
SOURCE: TV SCREEN GOES BLANK
Yes your inverter is bad, I have the same problem my set is about 1 and 1/4 years old. Because Olevia makes a terrible product there inverters are attached directly on to the panel, which means they will only sell the inverter along with the panel i.e $700+ to replace + $100 dollars labor if u don't know how to fix it ur self. I am currently searching to find the manufacture that makes the inverters because olevia will not disclose that information. I believe it is darfon, if so the inverter should cost about $150-200 depending. If you dont believe you can fix it ur self ur best bet is try and sell the set for scrap take ur $100 or so dollar and buy a quality product! Oh and dont call there support they will tell 10 different things before u find out this long for seen truth!
Posted on Jun 20, 2008
Anonymous
  • 8 Answers
SOURCE: u600 screen blank
Probably all due to a faulty flex cable that connects the screen to the main board.
I had simmilar problems so I replaced the cable and now the phone is fine.
Nick
Posted on Oct 16, 2008
A whirling noise when trying to take a picture and it won't focus or take a picture.
the sound you hear is the camera trying to focus, it sounds like it could be ready to give up.
Jan 07, 2014 | Canon EOS Rebel Ti 35mm SLR Kit w/ 28-90mm...
Problem with focus when taking video
read your owner manual troubleshooting section for to see what
is the exactly problem. They contain many tips for help
God bless you
Sep 24, 2012 | Canon PowerShot SX210 IS Digital Camera
Hi. I have a 16GB memory card. I checked it several times with h2testw software and it's working fine. After I shoot about 4GB I start getting "unidentified image" when I try to see the...
The canon PowerShot SX210 IS only supports memory cards up to 4GB in size. Larger ones will work, but because of the format type the camera uses, it won't be able to read correctly past 4 GB.
May 05, 2011 | Canon PowerShot SX210 IS Digital Camera
There's something wrong with the focus of my camera. Everytime I take a picture it's blurry and it won't focus unless I zoom in. Is there a way for me to fix it?
ensure finger is not covering auto focus.
ensure camera is not in macro setting. look for icon like a flower this is only for close up shots and will cause bluring if subject is too far away.
check that camera is set in auto focus and not manual focus mode if it has this.
I hope this was helpful.
Jan 24, 2011 | Canon PowerShot SX210 IS Digital Camera
I just bought the Canon PowerShot SX210 IS and when I record a video there is no sound what so ever... Can I please have some help. Thank you.
When you play the Video use the UP key to make the sound loud...try and see is it help?
The sound will be ok when you see it on PC
Jan 06, 2011 | Canon PowerShot SX210 IS Digital Camera
Hi, I'm an amateur with cameras & I just bought this camera - canon powershot sx130 IS and I just tried it out. When I press the shutter halfway I only hear one beep and I'm supposed to hear two beeps...
Every camera I've ever worked with only beeped once to confirm the focus lock. If your camera still takes in focus pictures, I would say "don't worry...be happy".
Dec 23, 2010 | Canon PowerShot SX130 IS Digital Camera
My Canon SX210 IS is brand new. Just bought it on yesterday. The problem I'm having is that the LCD screen does not look sharp and clear when focusing on a subject. It looks grainy. Can you tell me if...
Some cameras display a grainy picture in low light. Do you have the camera set to the highest number of megapixels and fine image or do you have it set to a lower resolution to get more pictures on the card?
Dec 03, 2010 | Canon PowerShot SX210 IS Digital Camera
Can i transfer photos from the computer back to my camera canon sx210
Sometimes it works but mostly, it corrupts the card and the camera. I wouldn't take the chance.
Aug 25, 2010 | Canon PowerShot SX210 IS Digital Camera
Troubleshooting
Refer to the manual if you have it. or Canon customer support if you do not
Mar 19, 2007 | Canon Rebel XT / EOS 350D Digital Camera
Cameras Logo
240 people viewed this question
Top Canon Cameras Experts
old marine
old marine
Ekse
Poul Brinchs Larsen
Are you a Canon Camera Expert? Answer questions, earn points and help others
