Some how my brush portion has gotton stuck in a more forward posistion than it should be. My husband has fixed this many times problem is he had a seizure last week and can not rember how he fixed it. Please help!
I know it is some thing EASY
Hi.
If you look at the front left side of machine there is a removeable inspection port it will have 2 coloured buttons you press these in & pull it up to remove.
Now pull handle back as if vacuuming the floor.
Now where the inspection port was you will see that there is a square hole pull forward on the flap in front of square hole it pivots just behind the round rubber seal.
Slowly lift handle back up at the same time The part with the 2 long grooves in it must go under the flap as you lift handle.
Chris.
