SOURCE: could you please let me know witch transducer to
Here are your options:
In-hull Mount Transducer (200/50 kHz, 12/45 deg)
010-10327-00
Thru-hull Mount Transducer with Depth and Temperature
010-10194-01
Bronze, Thru-hull Mount Transducer with Depth and Temperature
010-10182-01
Transom Mount with Depth, Temperature and Speed
010-10192-01
Transom Mount with Depth and Temperature (200/50 kHz, 10/40 deg)
010-10272-00
Thru-hull Mount Transducer with Depth (200 kHz, 12 deg)
010-10107-00
It all depends on the type of boat and how you are going to be using the fishfinder. Here is my email: [email protected] if you want to discuss your uses further and if you want to purchase a transducer.
Testimonial: "thank very much for info it was spoton"
The F1 fault code on this washer indicates that the water level pressure transducer signal is out of range. The pressure transducer air hose tubing being pinched or crimped can cause this. A failed pressure transducer on the machine control board can also cause it.
The first image below shows the method for accessing the pressure transducer tube that runs from the bottom of the washer tub to the machine control. I recommend checking this air hose for pinches, twists or crimps.NOTE: Be sure to unplug the washer to disconnect electrical power before accessing internal components.
If you find no problems with the pressure transducer tube, then the machine control board will need to be replaced. The procedure for accessing and replacing the machine control board is shown in the second image below. The part number for the machine control board is W10189966.
