SOURCE: Hit start button and nothing happens
read this page
http://www.repairclinic.com/0088_9_1.asp
SOURCE: dishwasher won't start
what is you model number?
you probably have a blown thermal fuse which is attached to the control board
SOURCE: no hot water. hitting reset button starts it up but keeps tripping breaker
-Did you buy it directly from Grainger? The model # is actually 82SV30-2T. The "model #" you provided is Grainger's product code.
-Is this a new installation or is this an older water heater?
-Is this wired to a 25 amp breaker. (It should be.)
-Did you re-use existing wire? If so, is it at least #10 copper? (It has to be #10 or larger to comply with code) It isn't copper-clad aluminum or cotton over rubber insulated, right? (It should not be)
-Have you re-wired the heating elements? If so, you need to restore the wiring to the way it was configured from the factory.
Let me know if you need further assistance.
V/R
SOURCE: E10 error code. I have to keep hitting the start
hi
it is water pump error ,,please check it thank u,,
please rate it
SOURCE: is their a reset button for a L800 HOBART? Hit start sparks flew.
Yes,
DISCONNECT POWER
if you remove the top cover, you will find an overload group with a green and a red button on top, next to the contactor . One is test, the other is reset. On the side of the overload are two thumb wheels, one is auto/ manual, set this to auto, the other is -15%,0, +15%. If you are running very heavy batches and you want to push your motor harder, move it to +15, but it's not recommended. If it was set to manual, when it trips and cools down, it will not reset untill you press the reset button, in auto, once cool you an restart the mixer.
Hello Vernon, thank you for your post!
From my understanding your Frigidaire dishwasher will not start after the cycle has been selected. This could be a potential issue with your keypad or control panel and I would recommend performing a reset. You can reset your dishwasher by flipping the household circuit breaker off for at least ten minutes. If the reset does not help correct your issue you may need to have an electrical component replaced. I would suggest having a professional technician out to perform a proper diagnosis and this can help you avoid any unnecessary part purchases. I hope this information is helpful to you. -Matt
