I originally selected the wrong Fitbit to set up account, when I selected the correct device it wouldn't let me set up account due to email address already being used in previous account. I managed to delete that email from the original account and set up a new account using my wife's email everything in new account set up but cannot synch
SOURCE: I cannot delete a wrong email address from Windows
Click on the contact icon on the toolbar, The Doubl Click onthe contact to open the properties for the contact you want to change, click on the Name and E-mail tab, then select the e-mail address below, at the right, select Edit, and that will allow you to change the address to the correct one. and select ok. Your change shou;ld be accepted.
SOURCE: Have 2 facebook accounts on one email address
you used the 1st email address for both accounts? okk. well, the last account you made will be the only one using that email. you are not able to log into that first one because it doesnt have an email to it... and if i guess corectly facebook probably deleted. try contacting that someone v.i.a. email/ text.
SOURCE: i accidentally deleted my facebook because i used
[email protected]
email this account, explain to them with what happenend. be polite, her name is Jada, shes going to give u a securtiy question, answer it MAKE SURE U BE POLITE AND TELL YOUR STORY!
All you have to do is write a nice paragraph explaining what you did EXACTLY, then provide as much profile info as possible - Name, birthday, network, religious/political views (if applicable) and profile link.
i wud also advice you to send a copy of the same mail to the following ids...
[email protected]
[email protected]
[email protected]
[email protected]
[email protected]
this is to ensure u get a speedy response from facebook..
good luck
SOURCE: Syncing Outlook 2007 email with iPad
You can sync apple ipad with outlook, there are different ways to do this, I will show you way where you can sync between your Google calendar outlook and your ipad.
Please follow the next steps.
* If you don't have a Google calendar then you can create one here http://www.google.com/calendar/
* Now you'll have to download the Google Calendar Sync, http://www.google.com/support/calendar/bin/answer.py?hl=en&answer=89955
* Follow Google instructions on How to sync Google calendar with outlook, you'll have to insert your email and some other steps that are details at the link above.
* Now it's the ipad turn, from SETTINGS on your iPad select mail then contacts and calendars now select the add account then select Microsoft exchange
* Still with the ipad, from within the Microsoft exchange enter your gmail/email address, leave the domain field empty.
* Enter your password into the screen. Select next from the upper right corner. A message saying “Unable to Verify Certificate” will come up, Click accept.
* A new window, populate the server field with “m.google.com" click next. A new window will ask you to select what will be synchronized from the Exchange server, make your selections and select done.
That's about it now your ipad is synced with outlook through your google calendar.
Hope this will help you with your problem syncing ipad with outlook
SOURCE: My husband and I use a shared email address. My
Do you urgently need an expert in hacks of all sorts like email spying,Bank account hacking, money transfer, school grade upgrade,travel ticket hack,phone unlocking? [email protected] is who you should give a try, he has proven to be efficient with his jobs .
