SOURCE: HP 3 button wireless optical mouse
Normal
0
Turn the mouse over and find the small
rest/connect button on the bottom of the mouse and press it.
This should connect the mouse to the receiver and work properly.
If not, try pressing the receiver button and then press the button on
the mouse. This should be done whenever you change batteries or
glitch.
Hope this helps you. Bud
SOURCE: Microsoft Wireless Notebook Optical Mouse 3000 help
I had the same problem.
Press the button on the underside of the USB, the green light will flash. Now press the reset button on the underside of the mouse. Your mouse should now work.
SOURCE: ihome ih9 wont work with 3rd generation ipod nano
Look at the Box and the Manual! 3rd Generation is not supported by iH9! Clearly marked on the Manual.
SOURCE: HP Optical Mouse right click button does not work
i've a usb mouse and r.click is not working
SOURCE: I just bought my mouse
Sometimes if you have the optical mouse on Black pads, that can be a problem. Sounds as you have the battery in right, Have you tried rolling the wheel, to make sure it isn't out of sight? Now if you had to install software for the mouse. Take out the receiver, (USB part) then uninstall the software. Then restart your computer, then if you have the software, run it, I wouldn't put the USB part in until it tells you to, then leave it , you may also want to try a different USB port this time. Reinstall follow directions, it should work. Hope this will help you,
