No openings in windows.
SOURCE: 5 digit code to unlock my 1997 Mercury Sable
It is located on the keyless entry module located under the drivers side dash. There will be a five digit code on the side of the box facing the passenger side. Enter the code and it should unlock. Follow owners manual to change the code, it will store both codes at the same time and either should work.
SOURCE: replace battery key fob mercury sable
thats how to replace the battery. stick something (a dime usually works) into the slot, and pry the 2 halves apart.
You wont break them.
SOURCE: Looking for shift solenoid on 1999 Mercury Sable
I believe these are internal you must drop the trans. pan down to access it.
SOURCE: power steering leak on passengers side of 1999 mercury sable.
If it "RED" in color, like p/s fluid, and coming from the BOOT, then its your p/s rack assembly.The unit has to be replaced and alignment reset. ..also check the HOSES they are prone to leak also...hope this helped..GL
