Ria Dos Ramos Posted on Aug 12, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Hi please help my panasonic workio 8020 gives error of add paper but there is paper
  • Susan Stoner
    Susan Stoner Feb 28, 2019
    Thank you Randy Schumann The sensor was stuck I unstuck it and now I am up and running.
Randy Schumann
Level 2:
Sergeant:
  • Expert 410 Answers
  • Posted on Aug 12, 2018
Randy Schumann
Expert
Level 2:
Sergeant:
Answers
410
Questions
0
Helped
87953
Points
956
Ria:
There is a sensor in the throat of the machine that tells if there is paper present. look in the area where the leading edge of the paper sits when paper is loaded. you should be able to see a small piece of plastic sticking up that looks like it would block the paper. That is the sensor flag. Slide a piece of paper in and make sure that it pushes the sensor flag backwards. If it does, the sensor is probably coated with paper dust. Use canned air to blow air at the bottom of the sensor flag to remove the paper dust from the sensor.
  • Ria Dos Ramos
    Ria Dos Ramos Aug 13, 2018
    Thank you i will do that thanx a mil
5 Related Answers
Guru Guy
Ken Shepherd
  • 95 Answers
  • Posted on May 21, 2009
SOURCE: IP address problem
What problem? Need more info! On the Panasonic brand, you input the IP address through the "function" mode- "general" settings... go to last menu item "key operator" the code should be 3 or 4 zeros. Then go to the IP address item and enetr in the IP adress. Now you MUST TURN THE MACHINE OFF AND BACK ON TO LOCK IN THE IP ADDRESS! Go back into general setting and "print general settings" to see if it's still the same address.
firecontrol7
Norman Weimar
  • 7035 Answers
  • Posted on Jul 21, 2009
SOURCE: Panasonic Workio 1810 - Tray 1 Add Paper Message
First why is the tray set for size A4 Paper. That is metric size paper for oversea locations. Should be set for 81/2"x11, or 11"x81/2.. is there any paper stuck behind the 1st tray? are the guides that hold the paper in place in the draw snug up aganist the paper in the draw. is the bottom sheet of paper in the stack/rem of paper benton the edge. All sheets of paper in the draw must be flat.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Anonymous
  • Posted on Oct 27, 2009
SOURCE: Have a Panasonic Workio 8020 machine, is showing
Change copier to Fax mode - Function button no. 7 (set mode) and then No.1 (user parameters)
Anonymous
  • Posted on Dec 12, 2009
SOURCE: i HAVE A PANASONIC WORKIO 8020, IT SAYS BYPASS A4-
The computer has sent a A4 size document to the printer and the printer is asking you to put a A4 size piece of paper in the bypass tray so it can print it. It may be an email A4 size that someone has sent you or check the settings in Microsoft Word print or page setup to see if it is set for Letter size, not A4 size.
Anonymous
  • Posted on Oct 23, 2010
SOURCE: drivers problems
dear sir
i want driver for Panasonic 8020 drivers windows7 64bit
I have Panasonic network printer workio 8020, Fault code J93 is showing on display but there is no paper misfed in adf.
There is a sensor that is either knocked out of position or broken. It is not that difficult to take apart if you are a bit handy. First remove the covers and then remove the top cover.
Our Panasonic WORKiO 1520 copier is giving us the error message
try and place the paper back on the tray properly for the censor to pick it i encounter this problem everyday but i just reset the paper.
Pleas; I want panasonic workio dp8020 drivers for xp, to use it as a prinert to print A3 , many thanks for you
Drivers for Panasonic WORKiO DP-8020 can be download from the Panasonic official support site. Drivers and all instructions are available here.
Let me know if any further clarification/ assistance is required.
Good Luck!
Dont forget to appreciate the solution if I could have been of any help!
CreativeTECH
1helpful
Xerox machine not working
if this is concerning a panasonic 8020 then the tray lift mechanism is faulty, a modified replacement will need to be fitted.
1helpful
1helpful
11helpful
3answers
Drivers problems
dear sir
Top Panasonic Office Equipment & Supplies Experts
Norman Weimar
Norman Weimar
ZJ Limited
ZJ Limited
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
