Check wiring from switch to plug in unit from plug to motor
Testimonial: "Ended up changing out the old motor, but still no "high" speed. No idea how to check the wiring, so have to get a professional to help. Not sure if a heating & cooling person or an electrician would be best to contact."
SOURCE: fan motor switch on 98 jeep cherokee only works on high
In many cases this is the result of the blower motor resistor having gone bad. They are often located in the housing that holds the blower motor but I cannot say 100% for sure with the Jeep Cherokee.
SOURCE: 1998 ford contour blower motor not working
I have a 1998 Ford Contour. Believe it or not the ABS and the Blower Motor share the same fuse. It's a yellow 60 amp and you have to take off the battery to get at it. Of course this happened twice in the 6 years I had the car, both times in the dead of winter. Tires Plus in Pennsauken, NJ replaced it. Other than that, no complaints with my Contour.
SOURCE: ac fan won't turn off
In my 2001 Town and Country without automatic temperature control, my heater/AC blower suddenly worked only when set on high. Usually, that problem is your blower resistor pack.
I had to search for the one in my van since the parts man wasn’t sure where it was except that he thought it was in the dash somewhere. (In some other vans it was under the hood.) My Haynes manual didn’t have anything on it except a picture showing it with the blower. I found it directly behind the glove compartment. Very easy to get to once you know where it is.
The glove box can be lowered all the way out of the way just by pulling in the sides so the rubber stoppers come out toward you. The sides bend easily to allow that.
The glove box being out reveals the resistor in the heating duct right in front of you. Just remove the two sets of wires and two bolts (10mm socket, I think) and the resistor pack slides right out. Then bolt in the new one an plug the wires back in (they only fit in one way). Fold the glove box back up and press the stops in to get them back in place and you are done.
The resistor pack only cost $12 and change at my dealer. It is part number 1-04885583AB which was a replacement for the same number with AA at the end, so I’m guessing they had a lot of trouble with the AAs and so made a better AB.
Last Winter my heater blower fan worked only on High. I changed the front heater/AC blower resistor pack and was surprised at how easy it is, but I had to figure it out for myself since my Dealer's parts guy was no help as to where the part lived and my Haynes manual was just plain wrong. This was on a 2001 T+C. I'd be very surprised if the 2001 Caravan was any different. Don't know what other year vans would be the same. I do know some earlier generations had this resistor under the hood and Haynes had is with the blower sort of behind the instrument cluster.
