SOURCE: Model & spring issue with an ol casio G-Shock when replacing batt
This spring is connector to caseback for transmitting sound. Get an eyeglass and find out on movement backplate written SPRING COIL and put it back. If there is no marking SPRING COIL then check for the hole with approx. same diameter as spring (must easy fit in). The hole shoud be empty with contact spot at the bottom. Put the spring in and close the caseback. Check alarm sound. If it works, you did find the right hole- if not, try again till you find the right one.
Good luck
Arthur
SOURCE: it is made in china?
Your watch is not fake. Japanese are employing workforce in China, Thailand and other countries, because labour there is much cheaper then in Japan. However, quality checks are of Japanese standards and your watch is exactly the same if it would be made in Japan. Rate me, plz.
SOURCE: how do i change the
browse through my tips and you will find link for all Casio watch manual downloads.
It's probably the small spring which makes electrical contact between the watch aluminum back and the outer housing, presumably to provide an electrical ground connection to the outside triple sensor. I've attached a photo with the location indicated by the yellow circle and arrow. It goes in the little hole and will fall out if you're not careful.
